Omelet's Rear Fender Mod! - Page 2 - JeepForum.com
post #16 of 27 Old 09-25-2011, 06:38 PM
DuncsJeeps
DuncsJeeps's Avatar
2006 XK Commander
Thanks, that's exactly what I was looking for
DuncsJeeps is offline
post #17 of 27 Old 01-19-2012, 08:23 AM
Camp
2005 WK
Quick question on this. Do you mod the top of the wheel well also, or only where you remove the weather stripping and plastic piece that is by the back door?
Camp is offline
post #18 of 27 Old 01-19-2012, 09:02 AM Thread Starter
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Just the front half of the wheel well where the weather strip is.
Omelet is offline
post #19 of 27 Old 01-19-2012, 11:11 AM
Camp
2005 WK
Cool thanks.
Camp is offline
post #20 of 27 Old 01-19-2012, 03:18 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Omelet:
When you say "took all the tape and plastic off" what do mean about the plastic?
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #21 of 27 Old 01-19-2012, 05:35 PM Thread Starter
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
I used plastic bags and tape to mask off the sides of the Jeep I did not want over spray on.
Omelet is offline
post #22 of 27 Old 01-19-2012, 06:13 PM
JeepN4KC
JeepN4KC's Avatar
Ahh, that plastic. Copy. Thanks.
~Mike~
WK
XJ
JeepN4KC is offline
post #23 of 27 Old 02-08-2012, 07:34 PM
paroxysym
2007 WK
so i was reading lifted_ups thread on JU, is the extended bumpstops an alternative to modding the rear fender nate? or is it needed in conjunction with the rear fender mod? thanks as always
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #24 of 27 Old 02-08-2012, 08:14 PM Thread Starter
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
You can extend the bump stops in the rear, but I would suggest rolling the fender first and then if your tires still rub then extend the bump stops. If you roll your fender you will maintain your wheel travel, where as if you extend your bump stops you will loss travel.
Omelet is offline
post #25 of 27 Old 05-08-2015, 07:35 AM
jd0110
2007 WK
This worked great for me this weekend. Easier than I thought. Only regret was using dremel to cut plastic molding, as it melted it more than cut it. This combined with being in a hurry left it a little messier than I would have liked. Otherwise, it looks great and rolling the fender was easy as well as painting it. Love to here what others used to cut the plastic trim. Thanks for the great guide!
2007 CRD QDII, OME HD, JK AEV Pintlers, 265/70/17 BFG KO2, 4xG Matrix, belly, RockRails, GDE ECO/HOT, UCF DIff, JBA Disco's
jd0110 is offline
post #26 of 27 Old 05-08-2015, 10:40 PM
nvrdone1
2007 WK
Nate - what kind of .25 spacers ?
nvrdone1 is offline
post #27 of 27 Old 05-09-2015, 09:39 PM Thread Starter
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
I had some steel 1/4" wheel spacers I used for a while. They aren't the safest though, I'd stick with bolt on hub/wheel centric ones.
Omelet is offline
