Omelet's LED Rock Lights - Page 21 - JeepForum.com
post #301 of 341 Old 05-07-2013, 08:56 PM
Roberthhhhh
what is the requirement in the relays? Wouldnt you be able to just run power through a switch and fuse to the lights?
Roberthhhhh is offline
post #302 of 341 Old 05-08-2013, 04:59 AM
jeremyc653
2005 WK
You could but relays are a fail safe so you don't burn your stuff up with them being cheap on amazon and coming with wiring harness for easy change when they blow. I'll let someone else chime in why they are so important
Build Thread: http://www.jeepforum.com/forum/f67/jeremyc653-build-thread-1423295/#post14245927
jeremyc653 is offline
post #303 of 341 Old 05-08-2013, 06:38 AM
Budasac
2005 WK
Relays are used for two reasons.
1- they allow you to isolate the new components from the factory wiring. You don't want to add any additional load to the existing wiring. (If you don't plan on splicing into any wiring to activate the lights then this wouldn't pertain).
2- many of us have multiple switches (3-5) for a variety of acc lights. Without relays you would have to run a 20amp circuit to each switch and the from there to the component. Using relays you're able to run 1- 5amp circuit to the switch bank to control all the relays. Group the relays together in the engine bay and the bulk of your wiring is all in one place with a minimal amount of wires passing through the firewall.
Certainly not necessary in all situations but it's the best/safest method. (IMO)
Budasac is online now
post #304 of 341 Old 05-08-2013, 07:30 AM
jeremyc653
2005 WK
Just who I wanted to chime in the expert on the subject
post #305 of 341 Old 05-09-2013, 10:08 AM
Roberthhhhh
Thank you. I think I've got it now.
post #306 of 341 Old 06-13-2013, 12:56 PM
Tbonfire
2006 WK
Where can I get these SPDT switches for the rock lights? All I can find is the covers but no switch bodys! Besides the momentary ones.
Tbonfire is offline
post #307 of 341 Old 06-13-2013, 01:13 PM
snobrdrkid07
snobrdrkid07's Avatar
OTRATTW switches. My personal go-to for switches. www.otrattw.com
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #308 of 341 Old 06-13-2013, 01:15 PM
Tbonfire
2006 WK
They are all out
Tbonfire is offline
post #309 of 341 Old 06-13-2013, 01:18 PM
snobrdrkid07
They are all out
Well snap, they sure are. Give them a call, the guy I speak to is always very friendly and helpful. They are also redoing their website so that may be a possible issue.
-Michael-
post #310 of 341 Old 06-13-2013, 01:24 PM
Tbonfire
2006 WK
Okay thank you!
Tbonfire is offline
post #311 of 341 Old 07-09-2013, 11:45 AM
Live4Jeeps
Mind telling me what gauge wire you used? Looks amazing and I can do my own wiring but I'm wondering if you found that perfect wire size, you know, not too much and not too little going through it. Thanks!
Live4Jeeps is offline
post #312 of 341 Old 07-09-2013, 12:34 PM
Budasac
2005 WK
Pretty much anything from 16-20 gauge should be fine. The LEDs all combined draw less then 5 amps.(Never added them up for an exact amperage but I have them on a 5 amp fuse with no issues.). I think I used #18 wire. You could likely go even smaller but then the wire is a bit fragile and susceptible to damage.
Watch your "+" and "-". Be sure to wire all the LEDs the same and bench test them. It'll save you the headache of lying on your back trying to repair a solder joint after they're installed.
post #313 of 341 Old 08-06-2013, 10:24 PM
SSnipes
This is an awesome thread to find. I have seen so many expensive rock light systems or halogen systems that provide to much intense light in one area. Thanks to the OP for this thread. I am going to order my lights soon.
As for wiring mine, I setup my offroad lights to work off of the high beam and since I don't have the factory fog/driving lights any longer I plan to use that switch, which only runs off the low beam, for the rock lights. If I come to a technical section and need a spotter to see I just go for the low beams. At that instance the offroad lights turn off and on come the rock lights. All can be deleted from operating with rocker switches that have a lighted indicator that these are on.
I hope I like it but I can change it any time to be manual rather dependent on whether I am running high or low beams.
'08 Jeep JKU Rubicon
4" TF Flex Arm, GY MTR with Kevlar 37", ASFIR bumpers, Rock sliders, aluminum skids
SuperWinch EPi9, EVO Gusset, sleeves, control arm rock sliders
Wife's - '01 Jeep Grand Cherokee 4.7L - Stock
ATS 245/70R16
SSnipes is offline
post #314 of 341 Old 08-07-2013, 06:27 AM
Jeepforthewin
2010 JK Wrangler
I wish i was inclined enough on how to do this kind of stuff. Would love to have some of these.
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #315 of 341 Old 08-07-2013, 08:41 PM
SSnipes
It is easier than you think? Surely you can find someone who can help you?
ATS 245/70R16
SSnipes is offline
Omelet's Hidden Winch Build Omelet WK Grand Cherokee & XK Commander Forum 129 08-07-2017 05:50 AM
Rock Lights Dreezy WK Grand Cherokee & XK Commander Forum 16 05-18-2010 10:02 PM
Rock lights! sid23man ZJ Grand Cherokee Forum 9 01-08-2009 09:09 PM
WJ rock lights StrokedWJ ZJ Grand Cherokee Forum 5 12-02-2008 04:26 PM
Rock Lights!!! JBassXJ ZJ Grand Cherokee Forum 15 01-07-2005 06:21 AM
