Omelet's Headlamp Project! - Page 11 - JeepForum.com
post #151 of 171 Old 11-24-2013, 10:23 AM
tfgnt16
2009 WK
I'm not sure if this was mentioned previously in the thread, but do the '08+ HID projectors come with the leveling motors housed inside the units, or are the a separate system? Just curious to know if you can get projectors with or without the motors or if they're a one size fits all part.
Incredible job by the way, with the headlights and your entire WK build!
2001 WJ Laredo 4.0L - Sold!
2009 WK Limited 5.7L HEMI
tfgnt16 is offline
post #152 of 171 Old 11-24-2013, 01:24 PM Thread Starter
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Originally Posted by 94jeepman View Post
Are projectors just a housing you put a bulb in or is it the bulb?
I don't know much about the projectors. And I'm trying to decide whether to do projectors or hids
Projectors are what you attach a HID bulb to that will correctly focus and project a proper HID beam. If you are planning to run HIDs then get a set of projectors (either '08-'10 headlamps like I did, or do a projector retrofit) That is the only correct and legal way to have HID headlights in our Jeeps.
If you get an OEM set then they will most likely come with motors, but the aftermarket replacements do not. Either one you can manually adjust the beam cut off, but if your Jeep came with factory HIDs then you will need the motors to have them work properly.
Omelet is offline
post #153 of 171 Old 11-24-2013, 01:45 PM
94jeepman
2005 WK
The only other thing to do is the spacer under the lights with the 08+? And everything else is plug and play
94jeepman is offline
post #154 of 171 Old 11-24-2013, 01:56 PM Thread Starter
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Not plug and play. You have to do some wiring on the headlamps and make or buy a relay harness. It's all fairly simple though if you are at all familiar with wiring.
Omelet is offline
post #155 of 171 Old 11-24-2013, 01:59 PM Thread Starter
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Also to keep this thread up to date, here's a link over to my build thread where I have revised my headlamps:
http://www.jeepforum.com/forum/f67/o...l#post17927402
Omelet is offline
post #156 of 171 Old 11-24-2013, 02:41 PM
94jeepman
2005 WK
Do the leveling motors level them automatically?
post #157 of 171 Old 11-24-2013, 05:26 PM Thread Starter
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Only if you have the rest of the system to support it. Basically if it didn't come on your Jeep, then you wont have the auto function.
Omelet is offline
post #158 of 171 Old 11-25-2013, 04:44 PM
94jeepman
2005 WK
Ok I've Google everything I can think of and can't find the projectors I decided to just retro fit mine
post #159 of 171 Old 11-25-2013, 07:39 PM Thread Starter
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
The set I used was off ebay, but the company has a website too. It was something like A&M auto parts or something like that.
Omelet is offline
post #160 of 171 Old 11-26-2013, 10:23 AM
tfgnt16
2009 WK
Just as Omelet said, if the Jeep didn't come from the factory with the HIDs then you don't have the system. There are two sensors, both on the right side, one next to the front axle spring and one next to the rear axle spring. These sensors are connected to a control unit beneath the right headlight. Technically, this system is supposed to adjust the pitch of the light beam in accordance with the angle of the Jeep's suspension. But more than not I find the system is quite quirky, especially in the snow and rain. Sometimes the headlights point too far down and won't adjust to "normal" height. Considering disconnecting the main control unit, but I'm not sure if it will throw a code or not; there isn't much information about this whole system.
tfgnt16 is offline
post #161 of 171 Old 11-26-2013, 09:13 PM Thread Starter
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
So here is an ebay link to a set like I bought:
http://pages.ebay.com/motors/link/?n...d=131029972728
You will also need a set of D1S bulbs (I'd highly recommend a set 4300k or max 5000k for the best output)
You will also need a set of Valeo 6G ballasts which you can usually find on ebay for about $50.
Anything else you want to do, besides wiring them in with a relay harness, is all extra.
Omelet is offline
post #162 of 171 Old 11-26-2013, 09:45 PM
94jeepman
2005 WK
Okay thanks for your help
post #163 of 171 Old 03-04-2014, 09:35 AM
Billbo1970
2009 WK
Hello Omelet,
I love that LED addition to your headlights!
I want to do it to mine too, but slightly different. I want to have LEDs circling both reflectors, tied into the "blinker" to come on with the accessory lights turned on, but to not blink when using the turning signal. I have experience installing/wiring stereo equipment, but no real electrical wiring knowledge. I'm guessing you run the wires to the blinker wire, and there's probably a 3rd wire that interrupts the flow of electricity to cause the blink when you're turning?
What would be the easiest way to do this, and do you recommend anyone in particular to buy the strips from?
Regards,
Bill
www.frchobby.com
Billbo1970 is offline
post #164 of 171 Old 03-21-2014, 08:18 AM
hxdrummerxc
2008 WK
Originally Posted by Billbo1970 View Post
Hello Omelet,
Did you ever figure this out?
I was sitting here trying to think of a cheaper way to get halo's for mine. I was thinking about the same thing, using a flexible led strip like Omelet's and just wrapping it around both circles. But I would just want white, and NOT to blink with the turn indicator.
Oracle is way overpriced. $200+ for 4 LED circles. NO THANKS, talk about 100% profit.
Also Omelet, Where did you get the led strips from?
08' Limited 5.7L QTII | Hemi Club #76 | RC lift | Custom painted headlights with Oracle LED Halos | Bwoody 4" Short Ram Velocity Intake | Flowmaster Super 44 & resonator delete | Superchips Vivid |
hxdrummerxc is offline
post #165 of 171 Old 03-21-2014, 09:06 AM
Billbo1970
2009 WK
I've had to put this on the back burner for now... life & all that
Regards,
Bill
www.frchobby.com
Omelet's Hidden Winch Build Omelet WK Grand Cherokee & XK Commander Forum 128 04-29-2016 07:17 AM
Omelet's LED Rock Lights Omelet WK Grand Cherokee & XK Commander Forum 340 09-16-2015 05:58 PM
Omelet's Rear Fender Mod! Omelet WK Grand Cherokee & XK Commander Forum 26 05-09-2015 09:39 PM
Hid headlamp help 2000blackxj WK Grand Cherokee & XK Commander Forum 6 12-14-2011 08:59 AM
headlamp fog removal nickaplease03 ZJ Grand Cherokee Forum 7 12-04-2008 05:30 AM
