Omelet's Build Thread (aka The Bison)! - Page 50 - JeepForum.com
 25Likes
post #736 of 2515 Old 04-01-2012, 04:34 PM
Valpacer
2007 WK
Enough rest. BACK TO WORK!
heheh
looking good man!
Dave
2007 WH Grand Cherokee CRD (Yup, RHD Australia)- 3" Exhaust, GDE Flash Tune, CRDSTU/SL Hybrid Lift & bash Plates, 4xGuard Rock Rails, Saguaro F & R Bars, RCV's, Warn 9.5cti-s, AEV Saverge Rims, Nitto Mud Grapplers, Snorkel, Custom Rear Drawers, On Board Air, BullyDog Monitor, Dual Batteries -
Valpacer is offline
post #737 of 2515 Old 04-01-2012, 05:10 PM
JBert
2005 WK
Who need's porn when you have Omlet's truck?
-Justin-
1988 YJ, 2005 WK
JBert is offline
post #738 of 2515 Old 04-01-2012, 11:17 PM
ngould1
Just browsed through all 50 pages! Awesome build, wish I could do this! Keep it going omelet
ngould1 is offline
post #739 of 2515 Old 04-02-2012, 10:56 AM Thread Starter
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Thanks Guys! I worked until 2300 last night, but the front is still not finished It is very close though. I wont get much done on it today, but I will be back at it tomorrow. I will get some pics up soon. It looks beast!!!
Omelet is offline
post #740 of 2515 Old 04-02-2012, 11:21 AM
Mainsail
2005 WK
Being able to comfortably do your work outside is a great bonus!
That's about the only thing I miss about CA though.
Poor grammar is something up with which I shall not put.
Mainsail is offline
post #741 of 2515 Old 04-02-2012, 12:24 PM Thread Starter
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Yes that is nice and about the only thing for you to miss
Omelet is offline
post #742 of 2515 Old 04-02-2012, 01:05 PM Thread Starter
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Ok, because I LOVE my OME front suspension I wanted to try to use it with the SL. I had a couple options. First I could use the strut assembly as is and add a 2" BB spacer on top of it to achieve about a 25" hub-fender measurement. This would retain the ride quality and weight control I like and give the ride height of the SL system. The bad thing about that route is down travel would suffer since there would only be a 2" spacer on top instead of a 4" SL spacer. Since down travel is one of the big reasons of getting the SL, that option was not looking ideal to me. Second option was to cut one complete coil off the bottom of the coils so they wouldn't ride so high. Then put the assembly back together without installing the preload plate included in the SL kit, and bolt the 4" SL spacer on the top. This should retain the ride quality and weight control as before (in fact it should be a little stiffer) and give the desired ride height. It will probably ride a little higher that the normal SL but, it should be a good combination of travel and weight control. SO I decided to give the second option a try! I acquired a set of Hemi XK coils just in case it doesn't work out
I disassembled the strut and removed the HD coils. I used a paint pen and marked where I planned to cut.
Then I took my angle grinder with a cut off wheel and clipped one coil off.
I put the strut assembly back together leaving out the SL preload plate. Then bolted the SL spacer to the top. Once installed it looked like this.
Here is a comparison between the OEM aluminum spindle (left) and the SL steel spindle (right). The thing weighs a TON! I didn't weigh it but once the hud and rotor are bolted on it has to be around 100lbs.
I still have the jack stands under it holding most of the vehicle's weigh, but the tires are on the ground holding some weight to keep anyone from walking off with the front tires How it sits right now.
Right now it looks like I have gained 3" of down travel
Omelet is offline
post #743 of 2515 Old 04-02-2012, 01:11 PM
BobG97
2005 WK
that looks awesome! i can't wait to see the completed project, its going to be a beast for sure!
BobG97 is offline
post #744 of 2515 Old 04-02-2012, 02:07 PM
AJeepZJ
2006 WK
There's no weight on the front end yet right? I'm looking at the CV angles o.O..
All Gear, No Skill.
AJeepZJ is offline
post #745 of 2515 Old 04-02-2012, 02:15 PM Thread Starter
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
There is a little bit of weight, but the CVs are fine. I tested the downward limits before I but everything together and they could drop farther. The tie rods are a different story. If the front went down another inch from the where it maxes out at now, they would be at their limit.
Omelet is offline
post #746 of 2515 Old 04-02-2012, 02:50 PM
USN_BlackWK
FLY NAVY
USN_BlackWK's Avatar
I'm really looking forward to seeing how this turns out as its exactly the plan I have for my front suspension after I get a winch. Keep up the good work!
Aug '16 COTM!
Aug '15 COTM!
2016 GMC Sierra Denali 6.2L The tow rig
USN_BlackWK is offline
post #747 of 2515 Old 04-02-2012, 08:13 PM Thread Starter
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Thanks bud! I will make more progress and have updates tomorrow.
Omelet is offline
post #748 of 2515 Old 04-02-2012, 09:38 PM
ryanlamb00
2005 WK
What paint did you use to paint those rims? They aren't the ones with truck bed liner are they?
ryanlamb00 is offline
post #749 of 2515 Old 04-02-2012, 10:24 PM Thread Starter
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
No they aren't the ones with bedliner, they are the ones I did last year. I used a graphite paint from PepBoys and a high gloss finish. They are painted the same way though except I didn't use any blue.
Omelet is offline
post #750 of 2515 Old 04-04-2012, 12:29 AM Thread Starter
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Well I am finished for the day! Another late night Everything is now installed! I just need to go out tomorrow and lighten up some bolts and check clearances. I'll post some pics tomorrow.
Omelet is offline
295/70/17 , 35" tires , 37" , 4x4 , fox , jeep wk , lifted , ome , omelet , ort , superlift , wk
Omelet's Hidden Winch Build Omelet WK Grand Cherokee & XK Commander Forum 128 04-29-2016 07:17 AM
Omelet's LED Rock Lights Omelet WK Grand Cherokee & XK Commander Forum 340 09-16-2015 05:58 PM
Omelet's Rear Fender Mod! Omelet WK Grand Cherokee & XK Commander Forum 26 05-09-2015 09:39 PM
Omelet's Headlamp Project! Omelet WK Grand Cherokee & XK Commander Forum 170 04-02-2014 06:27 PM
Hoax and Omelet Meet hoaxci5 WK Grand Cherokee & XK Commander Forum 24 04-25-2011 08:22 PM
