Omelet's Build Thread (aka The Bison)! - Page 136 - JeepForum.com
 26Likes
post #2026 of 2515 Old 08-27-2013, 07:21 AM
ca07wk
2007 WK
Originally Posted by Clone451 View Post
http://formverk.vortex.is/brettakantar/jeep/
These guys are making them...
Awesome!
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline
post #2027 of 2515 Old 08-27-2013, 07:54 AM
craigbru
craigbru's Avatar
2007 WK
Originally Posted by ca07wk View Post
Awesome!
Those are indeed awesome! I think you need to be a US based distributor for them...
Jeep-Core
craigbru is offline
post #2028 of 2515 Old 08-27-2013, 08:50 AM
ca07wk
2007 WK
Ill never turn down an opportunity
ca07wk is offline
post #2029 of 2515 Old 08-27-2013, 01:04 PM Thread Starter
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Thank you! I just reached century on your build thread, watching the progress is just awesome!
The pinch weld is obvious but I worry about the rear fender since the tire extends so much outside the lip of the fender. Cutting into the door can be a bit problematic. Where was your rubbing (the top at the front?)? If I go for the SL i'll be tempted to move the rear axle back .5-1" or so...
Do you know of any who has tried the long soft bumpstops used in lifting LC120s and 150s?
I'm currently looking for 10" wheels with 4-5" backspace.
I won't be adding much armour, just light ones for cosmetics at front and rear since my wheeling is not so much in rock and steep climbs as you guys do (more trails and rivers). But I'm getting fender flares and sidesteps to reduce gravel damage.
oh btw, I think your rig on 37s will make it historic!
It really depends on your wheel choice and backspacing. With the right setup the tires will tuck nicely into the fender. The bumpstop extensions SL includes in the kit are quite long (4") and even with mine chopped down to 3" my 35s don't rub the fender at full stuff.
If you are referring to air/hydraulic bumpstops I haven't seen anyone use them on a WK yet. I have thought about installing a set to make fine tuning easier. The rear would be easy to do, but the front would be more difficult. I'll probably give them a shot when I install some coilovers.
Those are pretty sweet! Just what I wanted to see! How much do those cost? Much better than what bushwacker will be making whenever they finally get their heads out of their butt!
YES!!!
I'll never turn down an opportunity
So true! Chris is on opportunities like a fat kid on a cupcake!
Omelet is offline
post #2030 of 2515 Old 08-27-2013, 04:06 PM
Y0ungGunZJ
or Nate on a lightbar......
_______._____. << ----Mine------____.____.
//_|__l__,\____\,___------Dads>> /l __,[____],_
l_--\__\__l---\[]llllll[]| -----------l--|_|-L-OllllllllO-
(o) )-o---(o) )---o-) ) ---------(o) )-o-(o) )--o-) )
Y0ungGunZJ is offline
post #2031 of 2515 Old 08-27-2013, 05:07 PM
Clone451
2005 WK
No, those around here who are building LCs use these long soft rubber bumpstops. The gray WK on that websites has them, but they had to be trimmed down a bit, since they are to wide for the springs. But the bump is always soft, it never feels like a hit. I'm going to see if I can find some photos.
They do look good, I've never really liked what bushwacker does, with the screwholes showing, but that's me. They are expensive though, the off-the-rack price here is about 1300-1400 USD, I think.
Clone451 is offline
post #2032 of 2515 Old 08-29-2013, 11:36 PM
ibeatmywk
2006 WK
Omelet did you do your alignment yourself or have a shop do it? Im putting my 2" BB on, on my next paycheck too. I cant wait.
ibeatmywk is offline
post #2033 of 2515 Old 08-30-2013, 12:08 PM Thread Starter
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
When I installed the SL I used a tape measure to get it close enough to not freak out the ESP so I could drive it over for a professional alignment. Without the IFS properly aligned the tires will wear unevenly, your handling will be a little off, and your suspension won't work as well as it should.
Omelet is offline
post #2034 of 2515 Old 08-31-2013, 07:59 PM
ibeatmywk
2006 WK
Super lift? Im only doing the 2" spacer lift from daystar and getting 31x10.5 wranglers from wally world for under a grand total.
post #2035 of 2515 Old 08-31-2013, 08:16 PM
jeremyc653
2005 WK
Ya hes got a modified super lift. Bb lift is good but you'll want to go bigger
Build Thread: http://www.jeepforum.com/forum/f67/jeremyc653-build-thread-1423295/#post14245927
jeremyc653 is offline
post #2036 of 2515 Old 08-31-2013, 08:39 PM
ibeatmywk
2006 WK
I know. Its all I can afford right now and I need new tires and dont want to dish 950+ for radials when I can get the 31s for cheaper. Is there a diy video or a thread for the BB install?
post #2037 of 2515 Old 08-31-2013, 09:16 PM
ibeatmywk
2006 WK
What size lift did you get the fit the rubi wheels? I found some for 375 so I might get those if I can figure out if they'll work with the BB and if ill need spacers
post #2038 of 2515 Old 09-01-2013, 02:54 AM Thread Starter
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
The lift height doesn't matter when you are talking about wheel fitment. The Moabs will fit with any or no lift, you just need at least a .25" wheel spacer up front in order for the brakes to clear the wheel. I run 1" spacers with mine, but most guys will use 1.25" or 1.5" if you like the tires sticking out that far.
Also it doesn't matter what lift you are installing, get an alignment after.
HEY, look at that 5000 posts!
Omelet is offline
post #2039 of 2515 Old 09-02-2013, 06:20 PM
ibeatmywk
2006 WK
Have you ever tried an alignment on your own? And is there a thread for putting om a BB?
post #2040 of 2515 Old 09-05-2013, 05:18 PM
ibeatmywk
2006 WK
Do you still have your mbrp exhaust?
295/70/17 , 35" tires , 37" , 4x4 , fox , jeep wk , lifted , ome , omelet , ort , superlift , wk
Omelet's Hidden Winch Build Omelet WK Grand Cherokee & XK Commander Forum 128 04-29-2016 07:17 AM
Omelet's LED Rock Lights Omelet WK Grand Cherokee & XK Commander Forum 340 09-16-2015 05:58 PM
Omelet's Rear Fender Mod! Omelet WK Grand Cherokee & XK Commander Forum 26 05-09-2015 09:39 PM
Omelet's Headlamp Project! Omelet WK Grand Cherokee & XK Commander Forum 170 04-02-2014 06:27 PM
Hoax and Omelet Meet hoaxci5 WK Grand Cherokee & XK Commander Forum 24 04-25-2011 08:22 PM
