Omelet's Build Thread (aka The Bison)! - Page 119 - JeepForum.com
 26Likes
post #1771 of 2521 Old 03-25-2013, 11:51 PM Thread Starter
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Ok enough teasing
Even though I don't live in a wet area or do any river fording, there are other benefits to snorkels that most don't think of when you think "snorkel". They are also great for keeping your intake filter cleaner. Particularly on those trail runs when you are behind other Jeeps who are kicking up clouds of dust. Not having your intake pulling in the air from your grill or fender well and instead pulling from roof height makes a big difference! Of course there is also the other reason... THEY LOOK AWESOME!!! Now we all know about the Airflow snorkel that has been out for a while:
Well no offense to anyone, but personally I think they look like a big turd or growth on the side of the Jeep! Not only that, but until repentantly they were about $600 (they are now around $500). So even though I have wanted a snorkel for some time now 1. there was no way I was ging to shell out $600 for that hideous thing 2. the wife refused to allow it on the Jeep (not that I was even trying to talk her into it) 3. I just didn't NEED one that bad.
I had decided that I would get creative with fiberglass at some point after completing a few more of my big projects of the Jeep I had been planning. That is until I found a guy on FB in Venezuela (I think) who was using something different. I tried to get as much info out of him as I could, which in the end wasn't much He said he used a Safari SS165-HF for an ISUZU D-MAX, but that his was fiberglass or something After looking at some not so clear FB pics and checking out Safari's site I wasn't so sure. I started looking at other models that Safari made and thought the SS160-HF for a diesel Rodeo actually looked better. SO I contacted our awesome bud Nick Kolak and he was about to really hook me up on one up in WA A few days later I picked it up from UPS just in time for the weekend!
Time to see what I was dealing with.
Originally I figured I would mount the actual snorkel and then use 4" pipe inside the fender to connect it to the filter box. After seeing just how much room I had to deal with in there, I might need to try and use the included inner piece. For now I turned all my attention to first seeing if this was even going to mount and line up right, and second making sure I wasn't going to butcher the fender and/or the snorkel in the process.
I started by removing the ORT8 badge and stripe on the passenger side. Then cleaned off all the goo and applied a layer of painters tape. I also removed the antenna.
The included template was a little too rigid for the curved fender of the WK, so I grabbed a piece of paper and made my own. Then I cut out the 4" hole so I could lay it flat against the back side of the snorkel and trace the edges of the snorkel on the paper. That way I could hold the snorkel right where I thought I wanted it and then tape the paper in place on the fender while visually lining up the edges. This insured me that the holes I needed to drill would be in the correct place. This also helped to see where I was going to be drilling on the fender so I could keep an eye on the lines and curves.
I had contemplated the idea of buying a fender off eBay to bolt on and use an a first draft, but ended up decided I didn't want to wait and if I took my time, then it should be fine. The big issue was that the snorkel has a 4" tube coming off the back of it that is an inch or two in length. This made it very difficult to properly see where and how the snorkel was actually going to lay on the fender and A-pillar. After adjusting the template many times. Standing back and looking. Re-adjusting and looking some more. Having the wife weigh in with her thoughts. Then looking at it some more. I finally decided to get the drill and do it already!
This took a bit of a gut check, but it needed to be done in order to really see how it was going to fit. I figured that if needed I still had some room to play with moving the snorkel around before you could see a hole sticking out the side of it
THERE I DID IT!!! Now the snorkel can lay flat and I can really see how she was going to fit. Before drilling the three mounting bolt holes I needed to make sure it was going to fit tight against the fender while also hitting the A-pillar correctly to bolt on. So I loosely mounted the included bracket to the snorkel and lined it up, only to find that the bracket wasn't going to work (not that I was surprised). So I pulled the weather stripping off the pillar and took some measurements. I first made a bracket out of cardboard then used a spare piece of aluminum.
After a few times holding it in place, pulling the bracket off to bend it, then holding it back up. I had this at the end.
The bracket happened to line up with one of the small screws holding the weather strip on. However the plastic needed to be modified slightly for a tight fit.
After being very careful with the dremel I ended up with this.
Now that I had the bracket finished I could continue fitting the snorkel. I replaced the small screw with a larger self tapping one. I will use two more later one so there will be three screws holding it in later, but for now I just needed the one to hold it in place. This was the first time I could mount it and stand back to see how it looked!
Omelet is offline
post #1772 of 2521 Old 03-26-2013, 12:19 AM Thread Starter
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Finally, I was so close! Now I pressed the snorkel against the Jeep good and tight to make sure this was where I wanted it before going any farther. I liked it so I only needed to adjust the template slightly using the outline I did before as a reference, and tape it down again.
Then I pulled the snorkel off, used a punch to mark the center of the bolt holes, and started drilling. I drilled them slightly larger than they needed to be so I wouldn't have any trouble getting all three to line up. Then I cleaned up the back side of all the cuts.
It was finally time to remove the tape and get the snorkel mounted with all the hardware.
First thing I did was place the snorkel on the Jeep and secure it with the A-pillar bracket.
Then put the weather strip back in place.
And made sure the door would still close
I plan to take it back off and paint the bracket and bolts black so they blend in.
I did a great job making the template, lining it up, and drilling the holes, because all three bolts went in no problem! Once they were all securely fastened here is how it looked.
It doesn't fit like a glove, but it definitely fits better than I was expecting. I thought I was going to NEED to whip out the bondo and fill in all the spots where it didn't sit flush and had huge gaps.
The hood does touch it when it's up, but that's not a problem. It also sits a little high so there is a gap over the top of the hood, but that was necessary. If I would have brought it down any more the bottom of the snorkel wouldn't have lined up with the fender where it flares out. Which would have made mounting more difficult and there would have been more noticeable gaps around all the sides. So I can live with the gap on top, and if not then I will whip out the bondo
Now for some different angles. The light was failing so the quality isn't that great.
This is just phase one! Phase two will be actually plumbing it into the filter box which I hope to get to here soon. Also, for anyone wanting to do this same thing I did keep the painters take intact and plan to make a template that I can mail off to anyone interested. That way most of the guess work is out of it. You will just need to line it up on your fender using the contours, and drill away That is at a small fee
Omelet is offline
post #1773 of 2521 Old 03-26-2013, 12:34 AM
rubiconkid4x4
2007 WK
And.. once again, another great mod that Omelet started that others will imitate. This is a very, very impressive mod, leader of the pack!! (again)
2007 WK - 5.7L - QDII
rubiconkid4x4 is offline
post #1774 of 2521 Old 03-26-2013, 06:46 AM
sixfoot9psu
2005 WK
That definitely looks like it was made for the wk! I agree that the other one is hideous!
'05 GC 5.7L Hemi QDII...Rock Krawler lift, 4XGuard Matrix, rock sliders, front and rear skids, belly guard, rear diff guard, Bilstein HDs, Volant intake, 265/70 Goodyear DuraTracs, Superchips, Rola roof rack, BORA wheel spacers, Rocky Road Leveling Spacers, Magnaflow muffler, KC Slimlights, BT catch can, tb cover, and underhood kit, Expanded Sheet Metal Grille
'09 G8 GT 6.0L...Kooks Headers, Rotofab intake, SLP exhaust, Vector Motorsports Tune
sixfoot9psu is offline
post #1775 of 2521 Old 03-26-2013, 06:57 AM
BAH101
2008 WK
Count me in for one of those templates.
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #1776 of 2521 Old 03-26-2013, 07:01 AM
06JeepXKHEMI
Usually not a fan of snorkels on both the XK and WK but this looks pretty slick! Great work..
05 LJRubi Currie 4" Springs, Savvy Fox shocks, MC trackbars, MC CA's single adj lower double uppers, 37x13.50 Cooper STT Pros on 17x9 ATX Ravine, MC Overlines front, Genright rear, Revolution 5.38s, Carolina Driveline driveshafts, MCAI
06JeepXKHEMI is online now
post #1777 of 2521 Old 03-26-2013, 07:14 AM
christiang26
2009 WK
That one looks great.
Is this the wk that has the fiberglass snorkel from a d-max?
christiang26 is offline
post #1778 of 2521 Old 03-26-2013, 07:22 AM Thread Starter
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Yep that's the one! His Jeep is a bright green now. He commented on one of my posts last night and apparently his IS a custom fiberglass snorkel that was based off the D-max design.
Thanks for the great comments! Hopefully the rest of it will turn out just as awesome.
Omelet is offline
post #1779 of 2521 Old 03-26-2013, 08:44 AM
05WKinPA
2005 WK
Hmmm....needs some pvc.....and the air intake should be INSIDE the cabin! Lol
Rocky Road & OME MD hybrid lift / AEV Pintlers / 32" BFG Mud Terrains / Four X Doctor rear diff guard / JBA UCA's / 4XGuard Belly Skid / Stillen cross drilled rotors
05WKinPA is offline
post #1780 of 2521 Old 03-26-2013, 08:46 AM
cherrybomb05
2010 JK Wrangler
07 WK
10 JKUR
11 JKR
cherrybomb05 is offline
post #1781 of 2521 Old 03-28-2013, 12:30 PM
LilOmelet
2005 WK
Very very nice... Can't wait to do this mod someday! Looks really good brother.
The Punisher - 05 WK 5.7L HEMI Limited QDII - Volant CAI - 2" Rough Country - Bilstein Struts - 265/70/17 Nitto Trail Grapplers - ASFIR Suspension, front diff. Skid - Mopar Fuel Tank, T-case Skid - Mopar (Borla) Exhaust
LilOmelet is offline
post #1782 of 2521 Old 03-28-2013, 04:11 PM Thread Starter
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Thanks bro! I can't wait until we get back and can tinker together
Omelet is offline
post #1783 of 2521 Old 03-29-2013, 09:51 AM
K9SAR
That snorkel really looks great! Gonna have to add that to the wish list. Your description of most of the other snorkels I've seen was spot on, putting the ugh in ugly (just my 2 cents worth)... heheheheheh
Pulled the trigger on the AEV/ SL lift w/ 6" JBA springs and am wondering if I could PM you for some details.
Tim
'06 Overland 5.7 Hemi / QDII / Silver WK Member #59, LED Backup lights, AEV Argent Pintlers, Floor liners. Gibson 3" Stainless Steel Exhaust, 6" Hybrid Superlift / OME lift, 6" JBA rear springs, JBA UCA's, JBA rear track bar, 35x12.5/17 Goodyear MTR's, Steel Armadillo Rock Sliders, 4xGuard Bash Plates
K9SAR is offline
post #1784 of 2521 Old 03-29-2013, 01:37 PM
SSF556
2008 WK
Very nice job....
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #1785 of 2521 Old 03-30-2013, 10:13 PM Thread Starter
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Tim
Sure thing bud, hit me up with whatever questions you have. I mean everyone else already does
Originally Posted by scootr29 View Post
Very nice job....
Thankd a lot bud!
Omelet is offline
295/70/17 , 35" tires , 37" , 4x4 , fox , jeep wk , lifted , ome , omelet , ort , superlift , wk
Omelet's Hidden Winch Build Omelet WK Grand Cherokee & XK Commander Forum 129 08-07-2017 05:50 AM
Omelet's LED Rock Lights Omelet WK Grand Cherokee & XK Commander Forum 340 09-16-2015 05:58 PM
Omelet's Rear Fender Mod! Omelet WK Grand Cherokee & XK Commander Forum 26 05-09-2015 09:39 PM
Omelet's Headlamp Project! Omelet WK Grand Cherokee & XK Commander Forum 170 04-02-2014 06:27 PM
Hoax and Omelet Meet hoaxci5 WK Grand Cherokee & XK Commander Forum 24 04-25-2011 08:22 PM
