OME MD, now want more! - Page 4 - JeepForum.com
post #46 of 78 Old 06-22-2013, 12:56 PM Thread Starter
WieSeL
Originally Posted by Omelet View Post
Possibly, but installing longer bolts into the OEM plate would be cheaper and you know they would be long enough and strong enough (grade 8). But if you by the aftermarket ones let us know how long the studs are.
Omelet, do you recall what the length is of the stock stud sitting above the stock upper strut mount?
WieSeL is offline
post #47 of 78 Old 06-22-2013, 03:00 PM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
I'm not sure, but you could compare it to the bolts I replaced them with by the pics in my thread. Or maybe someone else can get you a measurement.
Omelet is offline
post #48 of 78 Old 06-22-2013, 03:25 PM Thread Starter
WieSeL
Yeah it's hard to see exactly. Thanks neways
WieSeL is offline
post #49 of 78 Old 06-23-2013, 08:17 AM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Well the bolts I used were 2" long and judging by the size difference in the pic I would bet the OEM studs are 1.5" (where the threads end and the cone begins). So in order to run 2 strut spacers the studs need to be at least 1.75"
Omelet is offline
post #50 of 78 Old 06-23-2013, 02:57 PM Thread Starter
WieSeL
Ok thanks for the info. I will let you know how it goes
WieSeL is offline
post #51 of 78 Old 07-08-2013, 08:17 PM Thread Starter
WieSeL
First try resulted in a 1.25" of threads above the top of the strut plate. Going to try moog's strut plate next and if no better then going the route of aftermarket bolts or stud at 1.75" above strut plate
WieSeL is offline
post #52 of 78 Old 07-11-2013, 07:29 PM Thread Starter
WieSeL
So I've been looking at the JBA rear coil spacers. They apparently are 3/8". IM guessing you stack them on top of the factory lower spring isolator or on top and bottom. Anybody using these with any success? Thinking about just going with one spacer up front instead of two as it seems more hassle than anything and these JBA spacers for rear.
What is the standard for the "Modified OME"? as in what do others run in their rigs?
WieSeL is offline
post #53 of 78 Old 07-11-2013, 07:41 PM
SSF556
2008 WK
I just did....3 new JBA spacers on the drivers side and 2 spacers on the pax side....I got slight bump up in the rear...I am now over 22" from center of wheel to the bottom of the fenderwell....slight rake overall. That is what I wanted. With the HD OME I was sagging slightly in the rear.
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #54 of 78 Old 07-11-2013, 08:30 PM Thread Starter
WieSeL
Did you do anything to the front or just the OME coils?
WieSeL is offline
post #55 of 78 Old 07-11-2013, 09:08 PM
SSF556
2008 WK
Just the OME coils....if I ever put on a winch or metal bumper I would install the plates up front....
2008 CRD QT2
SSF556 is offline
post #56 of 78 Old 07-11-2013, 10:12 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
I recently tweaked my set-up.
OME HD - 4.7
Added Rusty's spacers up front.
Rear I piece mealed with 1/2 inch poly spacers both sides; 2 spring isolators top and bottom on driver side; 2 bottom-1 top isolator pass side.
I sit at 22.75" hub to fender all around with a rake.
I also added a Rusty's adjustable rear tracbar to dial the rear axle back in.
I didn't add anything else or change anything with regards to the OME Nitro shocks/struts, sway links, or brake lines.
I'm still on 265/70s and will most likely stay that way - though 285's would be a great fit.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is online now
post #57 of 78 Old 07-11-2013, 10:32 PM Thread Starter
WieSeL
What rear poly spacer did you use? IM having issues finding any besides what's in the daystar lifts etc.
Kinda wish I would of went with the HD, IM sitting low on the MD with the hemi up front but like the ride quality...
WieSeL is offline
post #58 of 78 Old 07-11-2013, 10:39 PM
JeepN4KC
JeepN4KC's Avatar
They were fabbed by another forum member and I got a couple he had left.
~Mike~
WK
XJ
post #59 of 78 Old 07-11-2013, 10:41 PM Thread Starter
WieSeL
Ah, damn
WieSeL is offline
post #60 of 78 Old 07-11-2013, 10:54 PM Thread Starter
WieSeL
Do any other rear spacers work, say for a jk or a wj? Probably been asked a million times
Sitting 21.75 up front and maybe 21 out back btw, after everything settled
WieSeL is offline
