OME MD, now want more! - Page 3 - JeepForum.com
post #31 of 78 Old 06-20-2013, 06:29 PM
sk1er18
2007 XK Commander
5100 adjustable struts
-Matt
sk1er18 is offline
post #32 of 78 Old 06-20-2013, 06:46 PM Thread Starter
WieSeL
Price?
WieSeL is offline
post #33 of 78 Old 06-20-2013, 06:47 PM
ca07wk
2007 WK
Originally Posted by WieSeL View Post
Price?
$230 shipped
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline
post #34 of 78 Old 06-21-2013, 12:50 AM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
The new 5100s are the easiest way to adjust the front up .75", 1.5", or 2". If you want .5" or 1" then you can use .25" strut spacers (1 plate = .25" and 2 plates = .5")
Omelet is offline
post #35 of 78 Old 06-21-2013, 07:31 AM Thread Starter
WieSeL
Do the 5100s change the spring rate at all or just move the spring up compared to the lower mount? So there is no way to stack a spacer without different strut mount studs? I wonder if aftermarket strut plates have longer studs...
WieSeL is offline
post #36 of 78 Old 06-21-2013, 07:37 AM
sk1er18
2007 XK Commander
The 5100s don't change the spring rate. They add preload to the spring by moving the lower perch up closer to the top mount.
-Matt
sk1er18 is offline
post #37 of 78 Old 06-21-2013, 07:55 AM Thread Starter
WieSeL
Changing preload theoretically changes spring rate by ultimately making the spring stiffer
WieSeL is offline
post #38 of 78 Old 06-21-2013, 08:03 AM
sk1er18
2007 XK Commander
Negative grasshopper. The "spring rate" does not change, nor does the spring get "stiffer" (which would be from a change in spring rate).
The reason you achieve lift by adding preload is because the unit compresses less as a whole to reach equilibrium.
-Matt
sk1er18 is offline
post #39 of 78 Old 06-21-2013, 08:22 AM Thread Starter
WieSeL
Ok agree it doesn't changed the designed spring rate but changes the point at when the spring starts to compress making it feel stiffer. The more preloaded the more force it takes for the spring to compress... Like if you add a passenger to a motorcycle add preloaded so the bike won't sag
WieSeL is offline
post #40 of 78 Old 06-21-2013, 08:31 AM
sk1er18
2007 XK Commander
Correct, it changes the point that the assembly starts to compress due to the additional preload.
.... making it feel stiffer. The more preloaded the more force it takes for the spring to compress...
The reason it feels "stiffer" is a bit more complicated. It has to do with dynamics and energy dissipation. Not because it takes more force for the spring to compress. Since the spring rate hasn't changed, once equilibrium is achieved the spring will still compress the same amount under the same additional weight thats applied (until it starts reaching full compression, then some interesting effects happen which make the spring rate go whacko).
-Matt
sk1er18 is offline
post #41 of 78 Old 06-21-2013, 08:49 AM Thread Starter
WieSeL
No I totally understand. Just don't want the "feel" of a stiffer spring. The preloaded "makes it feel" like a stiffer spring rate. That's why I got the MD kit
WieSeL is offline
post #42 of 78 Old 06-22-2013, 08:38 AM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
You can use the OEM strut plate studs to with 1 strut spacer (.5" lift), but if you want to use 2 (1" lift) you will need to swap out the studs for longer ones. You can see how I did it here:
http://www.jeepforum.com/forum/f67/o...l#post12813071
Omelet is offline
post #43 of 78 Old 06-22-2013, 09:04 AM Thread Starter
WieSeL
Yeah IM wondering if aftermarket strut mounts have a longer stud.
WieSeL is offline
post #44 of 78 Old 06-22-2013, 09:30 AM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Possibly, but installing longer bolts into the OEM plate would be cheaper and you know they would be long enough and strong enough (grade 8). But if you by the aftermarket ones let us know how long the studs are.
Omelet is offline
post #45 of 78 Old 06-22-2013, 10:18 AM Thread Starter
WieSeL
They are $34 my cost btw. Don't have access to a welder so idk
WieSeL is offline
