OME MD, now want more! - Page 2 - JeepForum.com
post #16 of 78 Old 06-18-2013, 06:24 PM Thread Starter
WieSeL
Originally Posted by trax95008 View Post
I got an all metal 1" rear spacer from BDS suspension.
Where do you find rear coil spacers less than 2 inches. Does any other spacer fit the wk like for a Wrangler? Can't find any under 2 inches anywhere. Is there any front spacers around 1/2 to 3/4 inch out there? Having issues finding anything under 2 inches rear and over 1/4 front (don't want 2 inch spacer kit for front)
WieSeL is offline
post #17 of 78 Old 06-18-2013, 06:39 PM
ca07wk
2007 WK
I think your going to have to cut down a rear spacer.
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline
post #18 of 78 Old 06-18-2013, 06:40 PM Thread Starter
WieSeL
I thought about that route
WieSeL is offline
post #19 of 78 Old 06-18-2013, 06:48 PM
sk1er18
2007 XK Commander
Get a set of JBA 4" rear springs instead.
-Matt
sk1er18 is offline
post #20 of 78 Old 06-18-2013, 06:55 PM
ca07wk
2007 WK
I wonder what the spring rate is compared to the OME. I may have to shoot Brent an email.
ca07wk is offline
post #21 of 78 Old 06-18-2013, 06:59 PM
sk1er18
2007 XK Commander
I know an XK who's recently gone that route that it worked out great.
Im running the 4" superlift springs. That's another option too. A lot of SL guys go with 6" JBA rear springs for a SL+ kit.
-Matt
sk1er18 is offline
post #22 of 78 Old 06-18-2013, 07:32 PM Thread Starter
WieSeL
Price? Not an option right now IM thinking
WieSeL is offline
post #23 of 78 Old 06-18-2013, 11:22 PM
trax95008
2006 XK Commander
Originally Posted by WieSeL
All I could find was there 2 inch spacer kit...
Their 2" spacer "kit" uses a 2" spacer up front, and a 1" spacer in the rear. That's because it's a leveling kit. If you call them, they will sell you just the rear spacers alone
trax95008 is offline
post #24 of 78 Old 06-19-2013, 05:35 AM
paroxysym
2007 WK
so you sat under 21" with the OME MD rear coils? was that with an empty cargo area? thats pretty low
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #25 of 78 Old 06-19-2013, 07:42 AM Thread Starter
WieSeL
Well that measurement was low because I originally had the rear coils reversed and had coil b on the driver side where I took the measurement and it was sagging on that side.
WieSeL is offline
post #26 of 78 Old 06-19-2013, 08:55 AM
trax95008
2006 XK Commander
The rears are not side specific. Only the fronts are
post #27 of 78 Old 06-19-2013, 06:04 PM Thread Starter
WieSeL
Um yes they are... They are labeled A and B, one is for driver and one passenger to compensate for the gas tank
WieSeL is offline
post #28 of 78 Old 06-20-2013, 05:14 AM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
What WieSeL said! Trax95008 you must be thinking backwards. With the OME coils the fronts are the same but the rears are side specific. Now the OEM coils are different, the fronts are side specific.
So you can go with the BDS rear spacers that measure 1" or if you want a little more the rear Rusty's spacers measure 1.5"
When I was running the modified OME lift with a bit of extra weight I was at 23" hub-fender (HD coils + 1.5" spacers). Then when I moved up to the SL I was netting 23.5" with the SL coils (new). Then I reinstalled the 1.5" spacers to bring me up to 25". A few months back I replaced the SL/spacer combo with a set of JBA 6" coils which have me sitting at the same 25" hieght. Except I need to add another isolator to the driver side because the Jeep is squatting a little.
Omelet is offline
post #29 of 78 Old 06-20-2013, 07:15 AM Thread Starter
WieSeL
Ok but how do I get the front to go up an inch? I like how it's leveled out right now and don't wanna go 1/2 in the front and 1 inch in the rear and then have it bird dogin'
Sorry just wanna do it right the first time ya know
WieSeL is offline
post #30 of 78 Old 06-20-2013, 05:55 PM Thread Starter
WieSeL
No ideas?
WieSeL is offline
