OME MD, now want more! - JeepForum.com
post #1 of 78 Old 06-01-2013, 08:33 AM Thread Starter
WieSeL
Just installed an OME MD and was thinking about adding the 1/4 spacers to the front to get an extra 1/2 inch in the front. Who makes rear 1/2 inch spacers as I can't seem to find anything out there... What is everybody using to get that modified OME in the rear?
WieSeL is offline
post #2 of 78 Old 06-01-2013, 09:05 AM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Since the rear sits a little lower than the front, most guys will use a 1.5" spacer in the rear.
Omelet is offline
post #3 of 78 Old 06-01-2013, 09:07 AM Thread Starter
WieSeL
Would that give it a raked look instead of level?
WieSeL is offline
post #4 of 78 Old 06-01-2013, 09:26 AM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Yes a little. What are your hub-fender measurements right now front and rear?
Omelet is offline
post #5 of 78 Old 06-01-2013, 09:55 AM Thread Starter
WieSeL
21.75 front and 20.75 rear. So I guess it would even it out. How hard is it to get that spacer in cuz it was hard enough getting things to line back up with just the ome spring installed
WieSeL is offline
post #6 of 78 Old 06-01-2013, 10:36 AM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Ya that would bring you up to about 22.25" front and rear. You can disconnect the rear shocks, sway links, track bar, brake lines, and notch the fuel tank skid for UCA clearance. All of that will allow the axle to drop far enough to get the coils in and out easy. I use a ratchet strap to help realign the track bar.
Omelet is offline
post #7 of 78 Old 06-01-2013, 11:45 AM Thread Starter
WieSeL
Ok where would I find the rear spacers? Can't seen to find them in that size
WieSeL is offline
post #8 of 78 Old 06-01-2013, 11:55 AM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Instal a set of these without the rubber coil isolator on the spacer end, and you will get 1.5" of lift:
http://www.rustysoffroad.com/jeep-su...ear-wk-xk.html
And here is the strut spacer:
http://www.rustysoffroad.com/jeep-su...tes-xk-wk.html
Omelet is offline
post #9 of 78 Old 06-01-2013, 12:05 PM Thread Starter
WieSeL
Awesome thanks for the help. Would you recommend a adjustable track bar?
WieSeL is offline
post #10 of 78 Old 06-01-2013, 12:10 PM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Do you plan to wheel it and really flex it out? If so then I'd say, yes get one. You not and you don't mind the axle being slightly over more to one side, then don't bother.
Omelet is offline
post #11 of 78 Old 06-01-2013, 12:11 PM
trax95008
2006 XK Commander
I got an all metal 1" rear spacer from BDS suspension.
trax95008 is offline
post #12 of 78 Old 06-01-2013, 02:40 PM Thread Starter
WieSeL
Would rather do it right instead of half ***'in it. Probly get it before the spacer. Is there a particular way of setting it up?
WieSeL is offline
post #13 of 78 Old 06-02-2013, 08:12 AM Thread Starter
WieSeL
Now are the OME shocks long enough for an extra spacer in the rear?
WieSeL is offline
post #14 of 78 Old 06-02-2013, 08:13 AM Thread Starter
WieSeL
All I could find was there 2 inch spacer kit...
WieSeL is offline
post #15 of 78 Old 06-02-2013, 09:52 AM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Originally Posted by WieSeL View Post
Would rather do it right instead of half ***** it. Probly get it before the spacer. Is there a particular way of setting it up?
I made mine 1/2" longer than the stock bar and that got it about perfect. It really just depends how far off the axle ends up being. It's better to have the axle either perfectly centered or slightly to the passenger side. That way the drive shaft will stay off the fuel tank while wheeling.
The stock shocks are 24" extended and the OMEs are 26". With a little more work you can run 28" extended shocks for a little more travel.
Omelet is offline
