OME install help please, quick reply if poss... - JeepForum.com
post #1 of 11 Old 07-05-2013, 01:26 PM Thread Starter
ChopprJock
2015 WK
Ok, I'm putting in my OME HD this weekend and I'm stuck. Got the passenger side front done with no problems but while disassembling the driver's side I can't get this bolt to come out...
It's the lower strut fork. I got the nut off of the aft side, no problem. But I can't get the bolt to come out... I've got the weight off of it, but it won't turn or anything. It's like it's fused on or something. I have already busted a 1/2" adapter using a breaker bar, my impact wrench won't budge it, and so far the bfh is no help. Any suggestions???
Yes, I used PB blaster for a few days before starting...
Lyn
Prior: 2005 Limited - SOLD. Now: 2010 Limited, Hemi, bone stock...for now!
ChopprJock is offline
post #2 of 11 Old 07-05-2013, 01:32 PM
R4TCHET
2005 WK
It's seized up, I think if you search for stuck clevis bolt there are some threads with detailed information. As for me I was able to whack it out with a hammer, another thing is to make sure it isn't hanging so there is zero pressure on it up or down if that makes sense
Sent from my Jailbroken iPhone using JeepForum
| (dark)KHAKI WK CLUB MEMBER 17 | 2005 4.7L QTII | JBA UCAs | Modified OME MD 3.5" lift | Rusty's Adj. track bar | 4XG Matrix | 285/70r17 Duratracs | 17" KMC Enduro Wheels | Rola Roof Rack | 21" Bean LED Light bar on Roof Rack | 2 12" Punch P3 Subs | Expanded Sheet Grille | SA Sliders |
R4TCHET is offline
post #3 of 11 Old 07-05-2013, 01:35 PM Thread Starter
ChopprJock
2015 WK
Thanks!
post #4 of 11 Old 07-05-2013, 01:39 PM
08hemi
2008 WK
The metal tab is just tack welded to the bolt, when I did mine, I just used a cold chisel and pliers to pull that tab off and then I was able to spin the bolt while tapping on the other side to free it up... and then got a new bolt/nut from the dealer. other than that.... good luck
08hemi is offline
post #5 of 11 Old 07-05-2013, 01:40 PM
SSF556
2008 WK
Put the nut back on the other end where is it flush with the end of the bolt and whack it with a hammer. Also go and get some anti seize and lube up all the suspension bolts, especially if you live in the snow belt.
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #6 of 11 Old 07-05-2013, 02:44 PM
nocojeep
1990 XJ Cherokee
I had a problem with that bolt on the driver's side when I went to put my lift on. The bushing inside the CA has a metal sleeve inside it and the bolt was actually rusted to the sleeve. I could turn the bolt back and forth about 1/2 turn, and it was just destroying the bushing. I soaked it with PB blaster for a week and used a torch and an air hammer and I couldn't get it to move. Ended up taking it to a buddy's shop and his tech used a sawzall and I don't even know what else, but he finally got it out. I ended up replacing both bushing to prevent this problem from happening in the future, bushings were about $30 each from NAPA. Good luck!
nocojeep is offline
post #7 of 11 Old 07-05-2013, 05:23 PM Thread Starter
ChopprJock
2015 WK
Thanks, guys. It's seized up pretty good... I'll prolly just destroy it and replace the bushings and bolt.
post #8 of 11 Old 07-05-2013, 05:27 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Take a heating torch to the bolt head - get it good and hot - usually works well on seized bolts.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #9 of 11 Old 07-07-2013, 08:36 PM Thread Starter
ChopprJock
2015 WK
Just an update: That sucker was seized up pretty darn good. I had used PBS Blaster on all the suspension bolts for about a week and it still wouldn't budge. My dad and I beat on it enough with a bfh and an impact hammer to flatten out both the nut and bolt ends! Managed to get a bearing press around it but to no avail. Finally ended up cutting the bolt and then stacking washers on the nut end while wrenching the (new) nut with breaker bars and an impact wrench. All told, took about a day and a half, including trips to the parts store. When it did come out it was bone dry, the blaster hadn't penetrated squat... Tough weekend but we got it done.
post #10 of 11 Old 07-08-2013, 06:15 AM
JeepN4KC
JeepN4KC's Avatar
Which is why heat is another option.
Glad ya got it done.
~Mike~
WK
XJ
JeepN4KC is offline
post #11 of 11 Old 07-08-2013, 07:45 AM
zc911
dunno if it's possible on the jeep, but Honda's have the same setup, and the same problem. What we would do is change out the strut without removing the fork. Unbold other things to get enough droop to pop out the strut and leave the lower fork
zc911 is offline
