OME HD Tire wear fix - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > OME HD Tire wear fix
Ring & Pinion's, Lockers, 4340 Axles, Install Kits, BaBilstein Blowout Sale - 4 5100 Series Shocks $309.99 shippSALE PRICING, Specials, Huge Savings Alloy USA and Posi-Lo
Unread 09-07-2014, 07:55 AM   #1
Pac Man
So I have noticed that the outside tread of my front tires is wearing MUCH faster than the tread on the inside. I have the OME HD, and It seems like the tires may not be "flat" on the ground anymore, but instead the top of the tires may be tilted slightly outward. I attached a picture of the outside tread and the inside tread.
Would these fix the problem?
http://4xguard.com/grand-cherokee-20...ted-wk-xk.html
I am getting new tires this fall and I don't want the same thing to happen to them!
2007 Black Grand Cherokee
Hemi - QDII - OME - S4XC Hidden Winch Mount -Talon 9.5SR - Full Matrix - 265/70/17 Duratrac's - Pintlers- Superchips - Magnaflow - Airaid - 5000k HIDs - Lightforce HID's - 4xG Front Guard - 4XG Diff Cover
Pac Man is offline   Reply With Quote
Unread 09-07-2014, 09:35 AM   #2
Discman03
2008 WK
Did you have an alignment done after the lift was installed? I had mine aligned right after installation because it was way off.
Discman03 is offline   Reply With Quote
Unread 09-07-2014, 10:51 AM   #3
colinzj
2006 WK
Like Discman said, the fix is an alignment. Unless they weren't able to bring the alignment back in spec, no, new control arms won't fix it.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is online now   Reply With Quote
Unread 09-07-2014, 10:54 AM   #4
NotDamian
Speaking of alignment, I have to go to a "special" 4x4 shop to get mine aligned because I have no idea what te specs are supposed to be. Does anyone know what the specs are? (Sorry for hi-jacking)
NotDamian is offline   Reply With Quote
Unread 09-14-2014, 05:46 PM   #5
skibum555
2005 WK
About to buy new tires and would like some info also, I also have spacers and most tire shops wont mess with my Jeep because its a "safety Concern"
Jeepin ain't easy...
Proud Member of the BlAcK wK club
MEMBER #105
skibum555 is offline   Reply With Quote
Unread Yesterday, 12:55 PM   #6
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Take the wheels/tires in and have them mounted and balanced as carry ins.
~Mike~
My Build Thread WK
My Other Build Thread XJ
'01 XJ with some stuff
Sept 2013 Cherokee of the Month
'07 WK with some other stuff
~RED WK CLUB #7~
'11 KK with mostly stock stuff
'06WK our first Jeep with stock stuff - totalled and gone
JeepN4KC is offline   Reply With Quote
