Oil Viscosity - Advice, Experience, Please - JeepForum.com
post #1 of 10 Old 09-19-2013, 05:28 AM Thread Starter
hdsport
2008 WK
'08 JGC, 4.7 V-8, 77,000 mi.
I know that the Owner's book calls out a 5W-20 oil viscosity.
I would like to put in 10W-30 for my winter stay in Florida.
Anyone see a problem in using 10W-30????
Also, will be doing a 2500 mi trip from Fla to Pa and back.
I lean towards the slightly higher viscosity for the Fla heat and interstate driving.
Your advice is appreciated.
Thanks.
2001 Winnebago Adventurer 32v Motor Home
2008 Jeep GC Limited Toad, 4.7 L V-8, QTII
US Army Vet, 8th Army, 11th Evac SMBL Hospital, Pusan, South Korea
In God We Trust
hdsport is offline
post #2 of 10 Old 09-19-2013, 05:58 AM
Jeepforthewin
2010 JK Wrangler
IIRC a different weight oil can mess with the MDS system and cause it to not work properly.
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #3 of 10 Old 09-19-2013, 07:52 AM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Mine is an '07 4.7 w/ 77K miles - I have always put full syn 5W20 in it.
Trust me when I say we see some heat in my neckathewoods during the heart of summer. Not to mention, some cold in the heart of winter.
I have driven mine short and long, wheeled it pretty hard, towed with it - in all weather conditions.
5W20 is just fine - I wouldn't bother swapping oil weights.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #4 of 10 Old 09-19-2013, 09:15 AM
yzjwk
2005 WK
4.7L engine = no MDS
Thanks.
Not sure if the requirements changed in 08 ,and wkjeeps does not list it, but my 05 owners manual and service manual state 5W30 for the 3.7/4.7L engines . But as stated above you would be fine with 5w20 . all the HEMI guys in florida and other hot climates are running it .
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #5 of 10 Old 09-19-2013, 09:32 AM
imthehink
You'll be fine, Iv'e been using 10w40 all all this year. And before that, I was using 10w30. Head to http://www.bobistheoilguy.com, more than you ever wanted to know about oil.
imthehink is offline
post #6 of 10 Old 09-19-2013, 09:42 AM
JeepN4KC
JeepN4KC's Avatar
Our last WK was an '06 and it took 30 weight. They switched from 30 to 20 between '06 and '07.
Long story short - If you can squeeze more miles per gallon out of the current set-up by merely changing oil weights, then it saves the auto makers a butt load of money. The 20 weight oil yielded slightly better fuel econ (and I mean slightly) when the engineers ran the engines through their rigamarole of tests. It's a case where the results are greater than the sum of its parts. From an individual perspective the difference is less than miniscule. From a manufacturer's perspective getting the best fuel econ for your entire fleet of built vehicles goes a long way with the gub'ment.
~Mike~
WK
XJ
JeepN4KC is offline
post #7 of 10 Old 09-19-2013, 03:05 PM
modernblueWK
Any of those oil weights will work fine. I use 5w20 because thats what the cap says??
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
post #8 of 10 Old 09-19-2013, 06:28 PM
LouC
2007 WK
I use the specified 5w/20 in my Hemi but Mobil 1 syn to desk better with high summer heat.
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
post #9 of 10 Old 09-19-2013, 06:45 PM
tjkj2002
2002 KJ Liberty
Funny that is the only change they did to the engine,just changed the oil fill cap.The 4.7 was designed for 5w-30 and can use 10w30 in hotter climates with no issues.I have run into issues at work from the 3.8/3.7/4.7's running 5w-20 and 0w-20 oil,mainly high oil consumption but when switched to 5w-30 or 10w-30 the problem goes away.
tjkj2002 is offline
post #10 of 10 Old 09-19-2013, 08:04 PM
modernblueWK
I use 5w20 full syn for summer wheeling and our -30 winters. No issues and no oil consumption. Im still under an extended maxcare warranty so im trying to follow the book as best i can.
SOLD 2008 WK 4.7 V8
