Oil Pan Removal Issues - 05 Laredo 3.7 - JeepForum.com
post #1 of 3 Old 10-05-2013, 03:24 PM Thread Starter
Clo
Ok - I've been at this for quite a while. I've read all the horror stories about oil pan issues and steps to removing this. I tackled this on my wife's 05 Laredo 3.7. I followed everything as directed by the FSM. Currently the motor is lifted for clearance and I have removed all the bolts from the oil pan. There is about a .5" opening all around the oil pan but it will simply not come off. Again, motor is lifted already so there is room to drop however it is stuck. I have tugged and wiggled it but something seems to be holding it. I am tempted to pry it off but afraid I might break something.
Need some expert advice please!
- Clo
Clo is offline
post #2 of 3 Old 10-05-2013, 06:46 PM
tjkj2002
2002 KJ Liberty
Your caught on the oil pickup and may not have enough clearance to wiggle it enough to gain enough room to unbolt the pickup tube.
tjkj2002 is offline
post #3 of 3 Old 10-08-2013, 12:24 PM Thread Starter
Clo
Oil pickup? Are you saying I need to unbolt the pickup tube the the pan to drop? What happens if I pull on the pan? I have spacing all around the pan but it seems to be stuck on something. I pull forward and backwards but it is not releasing. Can I simply pry it off??? What damage can I do?
Clo is offline
