Oil limitations - JeepForum.com
post #1 of 21 Old 12-02-2015, 09:13 PM Thread Starter
Jorghole
2005 WK
Oil limitations
I just got some new oil for the WK to put in this weekend but am not sure if it meets the specs. Can anyone tell me if they have tried Castrol Edge in their 5.7 HEMI and how well it worked out. I have been using Royal Purple for a while and that has worked very good but thought I would try something different. Now I wish I would have stuck with what I know.
2005 WK Limited, QD-II, 5.7L HEMI, Volant Cold Air Intake, 4" SL Lift, Rusty's leveling kit, DC Gun Metal wheels, 285/70-17 BFG AT KO, 4xGuard Front/Rear Skid, 4xGuard Diff Guard, SA Sliders, Gobi Rack, Cobra CB
Silver WK Club Member 55
Jorghole is offline
post #2 of 21 Old 12-02-2015, 09:21 PM
JakeWK
2005 WK
honestly, as long as you used the correct oil weight, you shouldn't have much of an issue.
05 WK HEMI
USN Jeep Club
CentralCaL 4X4
Colorado 4X4
JakeWK is offline
post #3 of 21 Old 12-02-2015, 09:36 PM
JRLT
2010 WK
The specs are on the bottle.
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline
post #4 of 21 Old 12-03-2015, 07:33 AM Thread Starter
Jorghole
2005 WK
There are specs called out on the bottle but not the jeep spec. That is why I am inquiring.
Anyone else use edge in their 5.7?
Jorghole is offline
post #5 of 21 Old 12-03-2015, 07:37 AM
10Xk
2014 WK
If it's not listed on the bottle then it more than likely doesn't met specs.
10Xk is offline
post #6 of 21 Old 12-04-2015, 03:58 AM
Marcus86GLHS
^+1.......if you cannot verify the oil meets the 5.7L OEM specs then you'd be well advised to get another type.
2008 Hemi Grand Cherokee Limited 4 x 4, original owner, 29,000 miles
Marcus86GLHS is offline
post #7 of 21 Old 12-04-2015, 04:24 AM
rebelbowtie
Or they didn't pay to have it "meet the specs" most any name brand oil will far exceed manufacture oil recommendations.
But for the sake of this thread and to help you sleep at night only put oil that states it meets the specifications in your vehicle.
rebelbowtie is offline
post #8 of 21 Old 12-04-2015, 06:42 AM Thread Starter
Jorghole
2005 WK
I think that would help me sleep better. I did the oil change last night with the Castrol Edge so I will just wait and see. Probably do a quick turnover on it. I did find online a cut sheet from castrol that says that it does meet the spec.
http://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/73A258BA225A396680257D03006D47BE/$File/EDGE%20US%20PDS.pdf
The other issue is the oil light and P0520 that I got earlier in the week. Same symptoms as indicated in the post that is linked.
http://www.jeepforum.com/forum/f67/c...-hemi-2963761/
Jorghole is offline
post #9 of 21 Old 12-04-2015, 07:49 AM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
What is it about the Castrol that makes you leery of it meeting specs for an 11 year old Jeep? Royal Purple certainly isn't a magic potion for WK HEMIs that nothing can stand up to. It's expensive motor oil - nothing more, nothing less. Assuming a regularly maintained service interval, most any oil out there with the proper weight is gonna work fine for your vehicle - to include parts store house brands.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #10 of 21 Old 12-04-2015, 09:33 AM
n7vrz
2005 WK
I have been driving vehicles of various types for around 50 years now. I try to buy the cheapest oil I can that meets the manufacturers recommendations. That usually turns out to be store brand oil.
I have NEVER had an oil related break down.
The high priced oil meets it too but I can't see paying extra money for the name.
On a side note: How many of you believe this commercial for oil that has "intelligent" molecules?
n7vrz is offline
post #11 of 21 Old 12-04-2015, 10:20 AM Thread Starter
Jorghole
2005 WK
The only reason that I even thought of the specs is after utilizing the cheap coolant I found myself in need of replacing the radiator because of leaks. Not saying that it was the cause but I did flush the whole system and got the better stuff.
Jorghole is offline
post #12 of 21 Old 12-04-2015, 02:33 PM
LouC
2007 WK
In the Hemi I'd use a good synthetic because of the fact that 5w/20 is required and using syn makes it less likely to have oil viscosity breakdown issues. The 5w/20 is very thin....
2017 JK Unlimited Sport 6 spd
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is online now
post #13 of 21 Old 12-05-2015, 09:01 AM
Montreal300
Montreal300's Avatar
Aww come on, where did you see that or what brand? I really can't believe any company would say that in a commercial. If it's true it would have to be in the running for the stupidest hook ever.
Montreal300 is offline
post #14 of 21 Old 12-05-2015, 09:03 AM
Montreal300
The MDS system doesn't like anything heavier.
post #15 of 21 Old 12-05-2015, 09:20 AM
PTee
I had Royal Purple my last 3 oil changes. I only buy it when it's on sale. I haven't found it on sale for ever so I just went to costco and got the castrol edge for like half the cost.
It's full synthetic and it's 5-20 I don't really understand what your concern is with using it. I don't even understand why, being on sale, made me buy Royal Purple.
2010 WK North Edition 5.7 Hemi, QT2, loaded Black WK #102
PTee is offline
