Oil Light Coming On/Off - JeepForum.com
post #1 of 13 Old 04-27-2016, 07:18 AM Thread Starter
DarthJeep
2005 WK
2005 4.7L @114K miles.
So today while stopped, my oil light would chime on/off on/off (flash and chime) until I would give it some gas. I haven't had a chance to check the oil level yet, but I suspect it's fine as I just changed the oil about 3 weeks ago and haven't noticed any leaks on the driveway. I don't get any messages on the EVIC for 'low oil' either.
I searched on one of the other forums and people were suggesting either the oil sensor or oil switch?
I'm leaning towards this as well, but wanted to ask around first.
Thanks.
Build Thread -
Black Wk Club 166
DarthJeep is offline
post #2 of 13 Old 04-27-2016, 07:55 AM
Bchain5
2007 WK
Thanks.
I have the same issue and it goes away once I restart the Jeep
My 7th Jeep, 07 Grand Cherokee QTII 4.7L
#164 of the Silver WK Club
My build http://goo.gl/sr5m5f
Bchain5 is offline
post #3 of 13 Old 04-27-2016, 08:46 AM
HTHM
2007 WK
The OIL LIGHT comes on and you don't IMMEDIATELY shut off and check your oil level!??
HTHM is offline
post #4 of 13 Old 04-27-2016, 08:47 AM
Bchain5
2007 WK
I did immediately and oil level was perfect. Doesn't sound like OP did
Bchain5 is offline
post #5 of 13 Old 04-27-2016, 08:53 AM
HTHM
2007 WK
That is who, (OP), the posting is directed at. No offense meant.
HTHM is offline
post #6 of 13 Old 04-27-2016, 08:55 AM Thread Starter
DarthJeep
2005 WK
Oil level is fine. That's why I'm leaning towards the sensor or something like that.
Build Thread -
Black Wk Club 166
post #7 of 13 Old 04-27-2016, 11:05 AM
Montreal300
Montreal300's Avatar
Edit: Removed comment.
Montreal300 is offline
post #8 of 13 Old 04-27-2016, 12:15 PM
caulk04
2008 WK
If it's only doing it at idle, it's pretty certainly not the sensor. Possible that it's reading lower than actual and setting the light since a hot idle will produce the least oil pressure.
Also, there is no 'low oil' light. No sensor to check oil level.
Quality oil and filter used?
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #9 of 13 Old 04-27-2016, 12:57 PM Thread Starter
DarthJeep
2005 WK
It's fine while driving, then at say a stop light, it will start chiming.
I used Mobile 1 synthetic 5w30 and the Mopar brand filter. Been using this combo for about a year no issues. I'm going to check the oil again afer work while its cool and see, but I'm betting a sensor as its driving fine and no leaks anywhere.
Build Thread -
Black Wk Club 166
post #10 of 13 Old 04-27-2016, 07:22 PM
Tango.
2008 WK
I had this happen once and it was a flake of metal got in the sensor. Sometimes it was vertical and got a good reading and the other times it was flat and the oil light came on. Gave me stress figuring out what was going on.
I ended up just replacing the sensor .. and when keeping and fixing the old one I figured it out.
Life is hard-John Wayne
Tango. is offline
post #11 of 13 Old 04-28-2016, 09:05 AM Thread Starter
DarthJeep
2005 WK
I checked the oil level again last night and this morning both hot and cold. Oil level is perfect, right at the top of the 'safety line' for hot and slightly above for cold. Still no leaks. I'm going to look at ordering a new oil pressure switch unless any here has any other suggestions?
Build Thread -
Black Wk Club 166
post #12 of 13 Old 04-28-2016, 10:07 AM
CRCs_Reality
2005 WK
I had this happen a few weeks ago (same situation, and all levels were fine).
I swapped out the oil pressure sensor and the problem hasn't returned.
2005 WK Limited, 5.7, QDII , 2" BB, 255/70R18's on JK Alloys <<== SOLD
Silver WK Club Member #116
CRCs_Reality is offline
post #13 of 13 Old 04-29-2016, 10:14 AM
1SiCv8
Ill echo this. Just had to swap mine. my old sensor had a lot of oil on the outside, probably from oil in the filter
1SiCv8 is offline
4.7l wk , oil change indicator , oil gage , oil sensor
