Quantcast Oil Drain plug lacation - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Oil Drain plug lacation
Old 05-05-2007, 05:56 PM   #1
hjasq
Sorry if this is a real stupid question.I have an '05 GC Limited with 5.7l engine.I always do my own oil changes(this is my 4th Cherokee) but I crawled under the car and can not find the oil drain plug(DUH). Can somebady clue me in as to its location? TIA
hjasq is offline   Reply With Quote
Old 05-05-2007, 07:27 PM   #2
05HemiQuadII
The plug is on the passenger side of the pan, towards the rear of the pan. Easiest if you take off the plastic skid plate, loosen the front (2) 13mm bolts, and remove the rear two bolts then slide it forward and drop it down. This gives you access to the pan and filter area. Good luck getting the PITA filter off. Wix filter is 51085, and you'll need 7 qts of 5W20.
05HemiQuadII is offline   Reply With Quote
Old 05-06-2007, 01:08 AM   #3
hjasq
Thanks a lot for your info.I bot the filter and oil just could not locate drain plug.See what you are talking about re PITA filter.Looks like a lot of 4 letter words will be involved.Thanks again.
Old 05-06-2007, 06:08 AM   #4
HurriJeff
2005 WK
Mine has the skid plate and mine is aligned with one of the access holes. Quite convinent actually! And the little flter drain lip keeps the oil from dumping onto the frame cross member.. Actually easier than my 4.0 6cyl because its all done from the bottom. I do wish it had a larger filter.
05 Grand Cherokee Limited 5.7 Hemi 265/65/17 Revos, K&N
HEMI CLUB MEMBER #10
Previous Jeeps:
1998 ZJ Special Edition 2wd- Traded
1991 XJ 2.8 2wd Sold
HurriJeff is offline   Reply With Quote
Old 05-06-2007, 09:11 AM   #5
T-Rated
Originally Posted by HurriJeff
How can I delete duplicate posts ??
You can't. The best you can do is edit the original post and replace all the text with something like [deleted].
Jeep: 2006 Midnight Blue Grand Cherokee Limited 4.7L • Bells • Whistles
Mods: Tow Hooks • Mopar & 4xGuard Skid Plates & Rock Rails • Flowmaster 70 • 255/65R17 REVO's
T-Rated is offline   Reply With Quote
Glock Forum
