oil catch can - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > oil catch can
Rugged Ridge 07-14 JK Sherpa Roof Rack available @ Oconee Rough Country Lift Kits and Parts!Great prices on seating!--Oconee Off-Road
Unread 08-26-2014, 09:35 PM   #1
davidtownsend
2006 WK
oil catch can
I know I should spend my money on a billet catch can but I don't have that kind of money. I want to get one asap. I was looking on e bay and found 15 dollar ones. I also found a 30 dollar one that I really like. I'll get a link soon. Has anyone gotten one of e bay that is a good one?
1994 Jeep Grand Cherokee 5.2L Limited
2006 Jeep Grand Cherokee Overland 5.7L Hemi
davidtownsend is online now   Reply With Quote Quick reply to this message
Unread 08-26-2014, 09:37 PM   #2
davidtownsend
2006 WK
This one look good?
http://m.ebay.com/itm/130927374642?nav=SEARCH
Unread 08-26-2014, 09:39 PM   #3
davidtownsend
2006 WK
Or this one?
http://m.ebay.com/itm/151277003733?nav=SEARCH
Unread 08-26-2014, 09:44 PM   #4
Shafer57
2006 WK
Will a cheap one hurt? Doubtful. But most real cheap CC's use a ball of steel mesh they shove into the main tank, and it's a PITA to clean. Versus a BT, or others that keep the mesh separate to make it easier to clean.
I'd save up and buy a BT, and keep it for years. But if money's tight, you could get by just fine with the eBay one, but it likely won't hold up as well as a quality unit.
Dodge Dakota R/T 360ci Small-block _sold_
Jeep GC 5.7L Hemi- Magnaflow Cat-Back, BT Catch Can, 20" Gloss black SRT Reps
275/45R20 Nexen Roadian, Blacked out, 180 Stat _SOLD_
2008 335i Twin-Turbo
Shafer57 is offline   Reply With Quote Quick reply to this message
Unread 08-26-2014, 09:52 PM   #5
davidtownsend
2006 WK
Thanks man. That helps a lot.
Unread 08-27-2014, 04:46 PM   #6
skibum555
2005 WK
Originally Posted by davidtownsend View Post
I think I am going to order this one too!! Ill let you guys know how it goes if you decide to go with the BT David.
Jeepin ain't easy...
Proud Member of the BlAcK wK club
MEMBER #105
skibum555 is offline   Reply With Quote Quick reply to this message
Unread 08-27-2014, 04:59 PM   #7
TangoTango
2008 WK
Hmmm .. That input hose is 9mm which is about 1/4" vs. 1/2" to 3/4" inch.
TangoTango is offline   Reply With Quote Quick reply to this message
Unread 08-27-2014, 05:14 PM   #8
davidtownsend
2006 WK
Would this be a problem?
Unread 08-27-2014, 06:05 PM   #9
caddydaddy
2007 WK
9mm is a 1/10" larger than 1/4", but your point is still valid!
2007 CRD Grand Cherokee Limited 4x4
GDE ECO Tune, Turbo Resonator Delete, EHM
166,000+ miles!
caddydaddy is online now   Reply With Quote Quick reply to this message
Unread 08-27-2014, 07:41 PM   #10
TangoTango
2008 WK
The point is that item is made for a small engine in a warm climate.
That small tube line may clog up and plug up, or freeze up which would them plug up the whole engine ventalation system which would be really bad and likely very very expensive unless the hose blew out, but that looks like a marine reinforced hose, so the hose will not break something much more expensive will break.
9mm is 23/64 inches ... point is vapor systems need 1/2" through 1" tubing so they don't plug up.
The best setup I have seen here it the pipe into the exhaust system, there was a good write up on it. This is how marine systems that are made not to fail are set up. When you are offshore help is usually far away. The parts for this setup were not very much.
