Off-roading with QTI? - JeepForum.com
post #1 of 12 Old 08-23-2014, 08:52 PM Thread Starter
Mikeb093
2008 WK
Hey Guys!
I did some searching but couldnt find anything on this site.. Has anyone used the Quadra-Trac I for light off roading? I have a buddy with a 2000 Cherokee and he found this field with basically a little trail in it that has some mud and some ruts in it, etc. He did absolutely fine in a stock 2000 Cherokee. I have a 2008 GC Laredo with the QT1 with no driver input. Would i be okay in that field? I know this is probably a very dumb question, as many of you are probably shaking your heads. But is the QT1 a sufficent 4X4 system for light off roading? Or should i avoid that until i get my RC lift and bigger tires? Thanks for taking the time to read this guys!
Mike
2008 WK, 3.7L, Silver with Tint, Blacked out emblems and Custom Grill mod. Lift coming soon...
Mikeb093 is offline
post #2 of 12 Old 08-23-2014, 09:07 PM
Rollin
It says Jeep on the front of the vehicle. Said vehicle also has 4x4. Drive it through the field. If you get stuck, have someone pull you out. There is no fun in it if you are always worried about it. Go out and have a good time.
1998 Jeep Cherokee Classic: Bull Bar, TracLock Chrysler 8.25"
Rollin is offline
post #3 of 12 Old 08-23-2014, 09:34 PM
caulk04
2008 WK
Turn off the traction control and have some fun.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #4 of 12 Old 08-23-2014, 10:41 PM Thread Starter
Mikeb093
2008 WK
Is the traction control the button that says ESP? Why should i turn that off? Would that help?
Mikeb093 is offline
post #5 of 12 Old 08-24-2014, 06:48 AM
chevra
2008 WK
Yes it is that button. With ESP on it will cut your engine power when your tires start to spin, therefore you will get stuck ha.
3.0L CRD OME HD
17" XD Addicts with 255/75/17 Dynapro ATMs
GDE Eco Tune and DPF Delete
chevra is offline
post #6 of 12 Old 08-24-2014, 07:36 AM Thread Starter
Mikeb093
2008 WK
Ah! Makes sense... Thanks!
Mikeb093 is offline
post #7 of 12 Old 08-24-2014, 09:52 AM
jeepin_in_a_wk
2007 WK
I bury my 07 Laredo up to the doors every time I go out and I always out do my buddies jk mainly because he's afraid to get it dirty lol.
jeepin_in_a_wk is offline
post #8 of 12 Old 08-24-2014, 06:05 PM
LouC
2007 WK
Maybe you should make sure you have some tow hooks front and rear first, that and one size bigger tires 245/70-17. I'd also remove that front air dam and add a 4xguard front skid. The WK is lower that the old style XJ and ZJ ESP in the front. There are hydraulic hoses right under the rad, hence the need for the front skid.
2017 JK Unlimited Sport 6 spd
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
post #9 of 12 Old 08-24-2014, 06:46 PM
BoraBora
2015 JK Wrangler
I wheel the piss out of my QT1. It's doable. Just fully turn off traction control and use good judgement.
'15 JK 2.5" lift on 35's
'06 WK 3.5" lift on 33's (Sold)
BoraBora is offline
post #10 of 12 Old 08-24-2014, 06:48 PM
ca07wk
2007 WK
Ive done quite a few moderate trails in the ol QT1, shes not a rock crawler but if you point the wheels and floor it, itll get you where you need to go
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline
post #11 of 12 Old 08-25-2014, 10:06 AM
oldsmoke
2009 WK
Only thing is you don't have 4Lo with QT1 so you can't lock axles front to rear. The ESP button just disables the stability program which is intended to improve directional stability ( stop you from going into a skid and losing control on slippery roads ). You don't want it on for mudrunning. The traction control on my Jeep with QT2 still seems to work with the ESP turned off. I have done some rough terrain hill climbing and the traction control pulls thru very well.
Diesel Ecotune-DPF, 32" tires, 2" lift. 4xGuard bib, tow hooks
oldsmoke is offline
post #12 of 12 Old 08-25-2014, 10:13 AM
LouC
2007 WK
We have wheeled our 98 ZJ on the beach many many times, it has open diffs, but with selectrac you can lock it in part time 4x4. Never needed 4-low. Never had a problem, aired down. It has Bilsteins and LT 235/75-15 tires on it. The WK can do well off road but its too low and the wimpy 65 series tires do not air down well. You need at least a 70 series to get good squat and not lose too much clearance. 245/70-17 is the minimum tire size that I'd use for wheeling a WK....
LouC is offline
