Odd Fuel Gauge Issue - JeepForum.com
post #1 of 8 Old 02-26-2010, 09:49 AM Thread Starter
Sciotojeeper
Last week when I started up my 05' GC (4.7) My fuel gauge was reading empty eventhough I had just filled up the evening before. As I drove to work, it slowly creeped up to 1/2 tank. On my way home that evening, it was reading 3/4 full, but than empty again the next morning! Any idea what the problem could be? Seems to fluctuate, but seemingly never accurate.
Sciotojeeper is offline
post #2 of 8 Old 02-26-2010, 11:16 AM
Walt
2008 WK
PITA check is to drop the tank and see if the float is hanging up. If it were not free, it could behave like the symptoms that you describe.
Of course, the best time is when the tank is nearly empty (and you never really know that or you wouldn't have posted here). Unfortunately, I think it's in the top of the tank with the fuel pump. I watched as the dealer dropped the tank to replace the one in my '00 GC Laredo (WJ). He used a jack and it was on a lift because the fuel tank was almost full and the recall had been issued by Jeep. Weight was 20 gal x 7 lbs/gal = almost 150 lbs!
If you do it, the resistance of the tank level float should go from min to max as it goes through it's travel arc. Can also verify that there are no burrs, obstructions or other foreign object hangups in the swing path.
Recommend that you first get underneath to verify that all electrical connections to the tank are tight & clean. May not be very easy, considering where they are (mostly on top). There may be room for a small mirror to look "over the top". Electronic contact cleaner sometimes helps remove corrosion. If you use it, be very careful, as some of these are highly flammable. Good ventilation is a must.
Please keep us posted. Best of luck and hope it's minor............
HEMI CLUB MEMBER #45; SILVER WK CLUB MEMBER #13
'08 WK GC Limited. 5.7L HEMI. Quadra-Trac II. Bright Silver Metallic. Class IV hitch.
Michelin LTX M/S tires. Fumoto oil drain valve. Billet Technology oil catch can.
Walt is offline
post #3 of 8 Old 04-17-2010, 10:38 AM
Texas WJ
Texas WJ's Avatar
2005 WK
Scioto, did you have any luck?
My gas gauge took a dump this morning. It's raining, a lot, and there's a ton of water on the street. So I hope when things dry out the gauge might return from vacation.
265/70-17 BFGoodrich All-Terrain T/A KO, 2" lift, JK Wrangler Moab wheels, Spidertrax Spacers, Rola Roof Rack.
Texas WJ is offline
post #4 of 8 Old 04-17-2010, 01:12 PM
merlinTec
merlinTec's Avatar
Hi
This is interesting love an update as if this was an export model there is a flash for CCN for this issues but can't see anything for the WK.
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #5 of 8 Old 04-18-2010, 10:15 AM
Texas WJ
Texas WJ's Avatar
2005 WK
Thanks Merlin.
What is CCN?
Yesterday, after a long break in the rain the gauge started working. Mostly. It was still intermittent, but mostly working. It was strange. One minute it would work, then after restarting the Jeep it would not. That leads me to believe it's not a stuck float.
It started raining hard again, about 2" in an hour or two like it does around here this time of year, and the gauge went out again. Today it's clear, so we'll see how goes.
Texas WJ is offline
post #6 of 8 Old 04-18-2010, 08:02 PM
Texas WJ
Texas WJ's Avatar
2005 WK
No problems all day today now that the sun is out. I'm leaning towards a problem with the connection at this point.
Texas WJ is offline
post #7 of 8 Old 04-19-2010, 02:12 PM
merlinTec
merlinTec's Avatar
Originally Posted by Texas WJ View Post
Thanks Merlin.
What is CCN?
Sorry CCN is the cluster.
post #8 of 8 Old 04-19-2010, 02:18 PM
Texas WJ
Texas WJ's Avatar
2005 WK
Thanks for your input as always Merlin.
Texas WJ is offline
Fuel Gauge Needle is dead... Low Fuel Light always on... any ideas? 95_JGC ZJ Grand Cherokee Forum 20 03-30-2015 09:30 PM
99 Grand Cherokee Fuel Gauge Issue Caleb5505 ZJ Grand Cherokee Forum 8 06-20-2011 08:15 AM
Fuel Gauge issue stew930 ZJ Grand Cherokee Forum 3 11-06-2008 01:19 PM
Anyone whos ever had a fuel pump issue, ASD relay, CPS issue, please read tbucket101 ZJ Grand Cherokee Forum 19 05-14-2007 09:15 AM
Fuel Gauge issue mcover WJ Grand Cherokee Forum 2 05-18-2004 07:19 AM
