O2 sensor fix - JeepForum.com
post #1 of 3 Old 07-02-2013, 11:04 AM Thread Starter
B_Baity10
O2 sensor fix
Any ideas on how much it is to fix an o2 sensor?
B_Baity10 is offline
post #2 of 3 Old 07-02-2013, 12:09 PM
JRLT
2010 WK
$30-$60 per sensor, gotta replace them. Do a search on Youtube, its basically unclipping the sensor and unscrewing it. Problem is, which of the four?
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline
post #3 of 3 Old 07-02-2013, 07:17 PM
90grandoneer
90grandoneer's Avatar
2006 WK
Which engine? Are you getting any codes? That will tell you which one(s) is/are the problem(s). They can be a PITA to replace, again, depending on which one is bad. If you have over about 75-80K on it, I'd just replace them all. I had one go bad at a little over 60K and replaced all of them. Cost me about $120 for all. Also, use the same brand that is in there now. The 5.7's run NTK's, a division of NGK. I had a problem with the fronts when I installed Bosch Sensors. Replaced them with NTK's and all was well.
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, K&N Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, DS Tuner, Cust tubular hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, SRT Reps with 265/45&295/40X20's.
90grandoneer is offline
