o2 sensor on a CRD - JeepForum.com
post #1 of 16 Old 04-25-2012, 04:59 PM Thread Starter
K5_Guy
2008 WK
o2 sensor on a CRD
I have a 2008 WK CRD and I am throwing 3 codes:
P2243 o2 sensor reference voltage circuit open bank 1 sensor 1,
P0131 o2 sensor circuit low voltage bank 1 sensor 1,
P0135 o2 sensor heater circuit bank 1 sensor 1
Questions are:
A) didn't know diesels had o2 sensors
B) Replaced plenty of o2 sensors before but cant seem to find this one
c) what is the correct part number as I am getting mixed results on parts searches.
Thanks in advance!
Dave
K5_Guy is offline
post #2 of 16 Old 04-25-2012, 06:09 PM
suzieque
2008 WK
Yup definitely a sensor there
My dashhawk shows the afr, the parts catalog i have does not show a part for the o2 sensor though. You should be able to find the sensor behind the cat perhaps the wires are damaged.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #3 of 16 Old 04-26-2012, 12:53 AM
fatfreddy
2008 WK
Questions are:
Thanks in advance!
Dave
The O2 sensor is on the top side of the CAT.You can see it if you look down at the rear of the engine bay passenger side.It is kinda hiding behind the 2 steel lines the come up from the DPF.
fatfreddy is offline
post #4 of 16 Old 04-26-2012, 05:34 PM
suzieque
2008 WK
Good photo, that would be it.
I would've expected 2 O2 sensors, 1 before the CAT and 1 after the CAT.
suzieque is offline
post #5 of 16 Old 04-26-2012, 09:11 PM
tnadanzig
tnadanzig's Avatar
2007 WK
You are correct. See picture of exhaust components.
CB Engineering
CB-engineer.com
2014 WK2 EcoDiesel - CBE Parts
2008 3.0L CRD WK LTD - GDE Tune 3.07 gears
2007 3.0L CRD WK LTD - Go Fast Parts
2005 KJ CRD - GDE Tune
tnadanzig is offline
post #6 of 16 Old 04-26-2012, 11:40 PM
fatfreddy
2008 WK
There isn't a down-stream O2 on my 2008.There is only 1 on mine on the top side of the cat.
post #7 of 16 Old 04-27-2012, 10:33 AM Thread Starter
K5_Guy
2008 WK
Thanks for the info! That looks fun to get too!
K5_Guy is offline
post #8 of 16 Old 04-27-2012, 06:35 PM
suzieque
2008 WK
now I'm curious, I need to have a closer look at my 2008 setup.
suzieque is offline
post #9 of 16 Old 05-13-2013, 11:55 AM
denniscdunbar
2008 WK
Did you fix this??
I have the exact same issue for my 2008 3.0L Grand Cherokee. What did you do to resolve this?
denniscdunbar is offline
post #10 of 16 Old 05-13-2013, 01:49 PM Thread Starter
K5_Guy
2008 WK
I had the sensor replaced. I ordered the sensor from mopar and was going to replace it myself, but it looked like I couldn't do it without dropping part of the exhaust and I didn't have that sort of time as i needed an inspection so I just let my local off-road shop do it.
sorry i wasn't more helpful, but it is now throwing the same codes so looks like I get to do it again!
Yay!
K5_Guy is offline
post #11 of 16 Old 12-09-2014, 11:00 PM
denniscdunbar
2008 WK
Was it difficult to remove the Oxygen sensor. I have the same error codes and would like to do it myself. Looks like I can get the sensor for $112.
http://www.factorychryslerparts.com/products/SENSOR-Oxygen--[Upstream]/4303711/05149012AA.html
Dennis
post #12 of 16 Old 12-10-2014, 09:56 AM
caddydaddy
2007 WK
Originally Posted by denniscdunbar View Post
It's on RockAuto.com for $100.79 and thier shipping charges are most likely less as well.
2007 CRD Limited w/QDII
GDE HOT Tune, Turbo Resonator Delete
2" RC lift
194,000+ miles!
caddydaddy is online now
post #13 of 16 Old 12-10-2014, 08:19 PM
ggrassmid
2008 WK
I was getting similar codes this summer. Unplugged, cleaned the connectors, and plugged back in. No codes since.
ggrassmid is offline
post #14 of 16 Old 12-13-2014, 09:28 PM
Tango.
2008 WK
you may want to check your air filter first (for too little), and the air system for too much or too little air (leaks).
Life is hard-John Wayne
Tango. is offline
post #15 of 16 Old 02-18-2015, 10:13 AM
brew1
I now have the O2 Sensor code(s). I'm curious about your procedure. Did you simply disconnect each O2 sensor (assuming 1 pre-cat and 1 post-cat per the diagram) hose down the electrical connectors with electronic contact cleaner spray, lube up each connector with dielectric grease, reconnect and clear codes? Did the codes stay cleared for more than a week?
Does anyone know if the pre and post cat O2 sensors are identical?
Another question a bit off-topic but I'm curious if the cat was replaced by a bypass pipe, is there still a need for the O2 sensors. I previously contacted GDE and they acknowledged they could adjust my programming if I eliminated the cat.
Thanks,
Mark
08 GC CRD, GDE
04 Audi A4 Wag 3.0, JHM, Revmax
03 Jetta Wag TDI, RC5, 17/22 turbo
brew1 is offline
crd , o2 , oxygen , sensor
high voltage o2 sensor/bad coolant sensor Jh24k WK Grand Cherokee & XK Commander Forum 1 07-19-2013 11:22 AM
hogh voltage 02 sensor/bad cool sensor Jh24k ZJ Grand Cherokee Forum 0 01-24-2010 11:33 AM
Sensor Reads Throttle/Pedal Position Sensor/Switch A Circuit Low Input Vincent2for2 ZJ Grand Cherokee Forum 3 11-01-2009 01:01 AM
Bank 1 Sensor 2 '01 Grd Cher o2 sensor location mgrean ZJ Grand Cherokee Forum 15 02-06-2009 01:41 PM
Crankshaft position sensor & coolant temperature sensor getting replaced in my 95 GC Keith1975 ZJ Grand Cherokee Forum 3 12-14-2006 04:52 PM
