not sure how i could be more upset. need to vent - JeepForum.com
post #1 of 17 Old 07-24-2012, 06:12 PM Thread Starter
PhantomOak
I bought a lifted 2006 overland WK in march with about 60k on it. ARB bull bar, warn winch, etc.
Well, about 6k and one oil change later, something caused the #4 cylinder to destroy itself.
Smashed the ends on the plugs, what the shop calls a indentation on the face of the piston from a valve, walls are scored, and piston has a gap against the wall where I guess it cracked or otherwise broke somehow.
Like 8500 fix. 3rd party Warranty will cover it if it originated in the engine, but not if it was foreign.
I have not even replaced the air filter yet so I can't imagine that I allowed something into the engine.
I have never seen anything like this in such a new engine. Any opinions? :/
I bought it from a medium size Toyota dealer. Fwiw
PhantomOak is offline
post #2 of 17 Old 07-24-2012, 06:16 PM
skizriz
1978 CJ7
It's not a new engine, it has 66,000 miles on it. The previous owner may have used and abused it.
A lot of times that's when they get traded in, when people see a big problem arising. They dump it off onto somebody else.
Drop a new motor in, what else can ya do. Bummer, but it happens.
skizriz is offline
post #3 of 17 Old 07-24-2012, 06:21 PM Thread Starter
PhantomOak
Oh, BTW. Upset about my jeep. I am not very real-life upset. Yet.
post #4 of 17 Old 07-24-2012, 06:22 PM
Tango.
2008 WK
a river crossing would do that ..... and that is probably what they will be checking for "water in the intake".
Likely they will find something "let loose" like a timing chain or gear tooth or valve clips or what ever ... lots of parts.
I wouldn't worry about it ...
Tango. is offline
post #5 of 17 Old 07-24-2012, 06:24 PM Thread Starter
PhantomOak
Ha. I am hoping that is the case. But like you said; bummer.
post #6 of 17 Old 07-24-2012, 06:50 PM
NGreen
2008 WK
$8500? Good lord man. You could almost buy a crate block for that much. Any junk yards around you could pull a motor from? Hell, if it'll cost that much to fix, might as well bore and stroke it!
NGreen is offline
post #7 of 17 Old 07-24-2012, 06:53 PM
06WKHEMI
2006 WK
I smell a 392 build coming
2006 Black wk overland HEMI QDII. OME HD bilstein struts with 58643 monroe load levelers RRO uca, afe cold air intake,hella 500FF behind grille, RC 1.5 wheel spacers s4xc cb antenna mount with 5ft firestik and midland 1001wx CB,265/70-17 falken rockymountain ats, pinch weld mod, door lock mod, Rola basket with 2 Hella 500 FF`s.
06WKHEMI is offline
post #8 of 17 Old 07-25-2012, 05:25 AM
paroxysym
2007 WK
that would be sick..
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #9 of 17 Old 07-25-2012, 05:29 AM
06WKHEMI
2006 WK
Hell yes it would!
06WKHEMI is offline
post #10 of 17 Old 07-25-2012, 05:32 AM
paroxysym
2007 WK
Hell yes it would!
but given the choice would you go 392 or would you rebuild a 4.7 with all the new 4.7 goodies out on the market? lol, i know its a no brainer but i was just thinking outside the box. plus looking on the air ram website, theres alot of crap going out for the 4.7- intake manifolds, rods, pistons, etc..
but given the OP has a hemi, may as well go bigger
OEM+
post #11 of 17 Old 07-25-2012, 05:40 AM
06WKHEMI
2006 WK
Total no brainer 4.7 vs 6.4 duh lol
06WKHEMI is offline
post #12 of 17 Old 07-25-2012, 05:56 AM
paroxysym
2007 WK
you hemi guys are all the same, no faith in the ol semi-hemi 4.7..
OEM+
post #13 of 17 Old 07-25-2012, 07:09 AM
06WKHEMI
2006 WK
Rofl a wise man once said my hemi gives me a hemi so who needs a semi hemi lol...and Tim the tool man always said MOAR POWER
06WKHEMI is offline
post #14 of 17 Old 07-25-2012, 07:11 AM
06WKHEMI
2006 WK
And am I detecting a slight hint of jealousy is somebody feeling a bit....underpowered lol ;-)
06WKHEMI is offline
post #15 of 17 Old 07-25-2012, 07:20 AM
SSF556
2008 WK
You could throw a diesel in there....
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
CCV vent on CRD?? NetworkMD WK Grand Cherokee & XK Commander Forum 40 12-27-2016 03:00 PM
AC Vent tab connerorr88 WK Grand Cherokee & XK Commander Forum 11 09-08-2015 08:45 AM
Hit and run... Need to vent fclensy WK Grand Cherokee & XK Commander Forum 3 07-02-2012 08:34 AM
Heater Vent Help? Outlawstar98 ZJ Grand Cherokee Forum 3 03-12-2009 11:26 AM
Wj Vent Problem?? HawkeyeWJ ZJ Grand Cherokee Forum 10 04-08-2006 09:49 PM
