Noob Lift question - JeepForum.com
post #1 of 8 Old 09-08-2012, 10:57 PM Thread Starter
Yillb
Noob Lift question
sorry for sounding a bit slow beforehand.
Im wanting to go through shallow water, about 2 - 4 inches, no more than 5. I was wanting to put a small lift on the Jeep ( maybe two inches ? ) ride quality id like to stay about the same, and i don't want to have to "tune" anything, would in need bigger tires ? would i need to tune anything, would 2 inches be enough to be going through that kinda water anyways, this isn't for mudding or going fast through any type of off road stuff either, i just go through a lot of murky / 3-4 inch deep water for work.
sorry if this was covered, i couldn't even find a search button.
It's the 3.7, non 4x4.
Yillb is offline
post #2 of 8 Old 09-08-2012, 11:08 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Stock WKs can ford 18 inches of water per the owners manual.
Putting a lift on your Jeep doesn't require anything else. The reason people put bigger tires on a lifted rig is the tire size determines your clearance - not the lift. Not to mention, lifted rigs withstock size tires look - well - stupid. The reason folks add a tuner is to recalibrate the shift points in the tranny and recalibrate the speedo due to bigger tires.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #3 of 8 Old 09-08-2012, 11:10 PM Thread Starter
Yillb
so lifting and adding larger tires will make the speedo wrong, unless calibrated correctly ?
Also, thanks for the info, i had no idea 18in was safe.. that kinda makes me feel stupid now lol .
Yillb is offline
post #4 of 8 Old 09-08-2012, 11:11 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Stock.you can cross water 12"+ deep without issue. If you are concerned you should extend the breather hoses for the trans and t-case. The one for the t-case is most likely sitting on top of the t-case. Do a search, there are a few threads about it here.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #5 of 8 Old 09-08-2012, 11:15 PM
JeepN4KC
JeepN4KC's Avatar
Only the tire size will affect the speedo, Odo, tranny, etc. If you increase the diameter of the tire it will turn fewer times than the stock size while traveling the same distance.
~Mike~
WK
XJ
JeepN4KC is offline
post #6 of 8 Old 09-08-2012, 11:16 PM Thread Starter
Yillb
is doing the lift something i can do myself ( not mechanically inclined ? ) ive never even see one done.
and im not concerned so much as i am worried all the sticks floating in this nasty water will just screw up the paint, which is why i was hoping to keep the bottom of the actual paint from getting wet. i figured another 2 inches, and id be clear for the little waves, and such.
Yillb is offline
post #7 of 8 Old 09-08-2012, 11:21 PM
JeepN4KC
JeepN4KC's Avatar
If your not mechanically inclined I'm guessing you don't have a relatively decent collection of tools - so I'd say no to installing the lift yourself. Otherwise, install of most lifts is definately doable by the DIY driveway "mechanic."
3 - 4 inches of water is nothing to be concerned about even at stock height as that isn't even going to be above your hubs.
~Mike~
WK
XJ
JeepN4KC is offline
post #8 of 8 Old 09-08-2012, 11:24 PM Thread Starter
Yillb
Awesome, thanks for the help guys. I could be wrong on the height of the water, as i do it in a company car atm, and it's well up to the bumper. But now i have a much better idea, thanks so much very helpful
Yillb is offline
Another noob question. Formula for keeping CoG when you lift? KDOG2008 ZJ Grand Cherokee Forum 2 06-12-2010 07:38 PM
NOOB tryin to learn.. Lift/tire question?? **WJ** EvilWJ02 ZJ Grand Cherokee Forum 11 03-02-2009 07:46 AM
noob lift help kidA ZJ Grand Cherokee Forum 4 10-20-2008 05:25 AM
lift Q's/ ZJ noob KKiowaTJ ZJ Grand Cherokee Forum 4 08-30-2007 02:25 PM
hi-lift noob - jack points? crozzer ZJ Grand Cherokee Forum 10 08-16-2007 07:34 PM
