Noisy ome lifts, get in here!!! - JeepForum.com
post #1 of 1 Old 07-23-2010, 02:51 AM Thread Starter
Pac Man
Pac Man's Avatar
Is your OME lift making funny noises?
For gods sake tighten that top strut nut ALL THE WAY DOWN.
Make sure the nut on the top of the strut is cranked down ALL THE WAY. It's also easy (since the strut shaft spins when you turn the nut) to under tighten it.
Initially I installed mine with the nuts too loose. I used a Dremel tool and widened the peepholes in the engine bay that the top of the strut shafts poke through. (this eliminates having to take the strut assembly completely out) One was under the fuse box and one was under the coolant tank. I was then able to hit both strut nuts with a high speed impact and I was amazed at how much they tightened up. TIGHTEN THEM UNTIL THEY BOTTOM OUT AND DO NOT SPIN ANYMORE. All the weird noises I had vanished.
I had to use 2 prybars to pop the bumpstops back in. Pull them down and grease them up so they slide in better. Mine aren't all the way seated, but I haven't had any issues and I have no noises.
Every week I see a thread from someone who followed some write up that instructed them to tighten the top strut nut down only a few turns. WRONG WRONG WRONG.
Oh, and REMEMBER to torque the rear shock bolts exactly to spec.
Top- 70 lb/ft
Bottom-85 lb/ft
2007 Black Grand Cherokee
Hemi - QDII - OME - S4XC Hidden Winch Mount -Talon 9.5SR - Full Matrix - 265/70/17 Duratrac's - Pintlers- Superchips - Magnaflow - Airaid - 5000k HIDs - Lightforce HID's - 4xG Front Guard - 4XG Diff Cover
Pac Man is offline
clunk , lift , noise , ome , rattle
What lifts are true 2" BB lifts? wakeskate420 WK Grand Cherokee & XK Commander Forum 3 06-30-2010 07:10 PM
Noisy Noisy Noisy interior Grand2626 WJ Grand Cherokee Forum 1 04-19-2010 10:36 AM
Still Noisy! MeWJWifeZJ ZJ Grand Cherokee Forum 0 10-10-2008 10:53 AM
noisy 4.0 sandman ZJ Grand Cherokee Forum 1 06-18-2007 11:06 PM
4.0L known to be Noisy?? jeepunlimited ZJ Grand Cherokee Forum 23 11-18-2006 09:53 PM
