Noisw in front end on bumps, its not the sway bar bushings/links - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Noisw in front end on bumps, its not the sway bar bushings/links
WJ Shackle Tabs: Tow-Hook Replacements2014 Spartan Locker Special - While Supplies Last! Dana 3FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 03-09-2014, 05:31 AM   #1
xjtrailrider
Noise in front end on bumps, its not the sway bar bushings/links
This started 3 weeks ago.
09 Hemi Limited XK, QT2, no lift, stock tires, 40,000 miles
The noise seems to be limited to the passenger side
I did a search and found that the sway bar bushings are the usual culprit. I inspected them and found there was some distortion. I replaced the bushings and end links with brand new Moog OEM replacements.
That made no difference. I jacked the pass side up and did a ball joint/TRE check and there is no play there. I found the rotor dust shield was vibrating and was able to fix that.
I can kick the front of the tire and and hear something that sounds similar. I'm also getting this noise when applying the brakes at low speed.
Im stumped
xjtrailrider is offline   Reply With Quote Quick reply to this message
Unread 03-09-2014, 10:28 AM   #2
xjtrailrider
Help out guys! Someone else has bound to have had this issue. I need to get it fixed ASAP.
Unread 03-09-2014, 10:37 AM   #3
tom19511
2006 WK
Does your Jeep have a plastic skid plate? Mine was loose because of a broken bolt. How about the wheel? Is it tight? What kind of noise? rattle? squeal?
Any vibration or pulsing when braking?
Tom19511
tchristopher1@wowway.com
2006 Grand Cherokee Laredo 3.7
2007 Liberty Sport 3.7
tom19511 is offline   Reply With Quote Quick reply to this message
Unread 03-09-2014, 12:26 PM   #4
xjtrailrider
Negative on al of those.
I dug deeper and found that the pass side lower ball joint has 1/4" up/down play in it. The drivers side has some but minimal.
