Noise at cold startup? - JeepForum.com
post #1 of 30 Old 12-23-2013, 11:31 AM Thread Starter
tok204
2005 WK
It has been -35 to -40 here off and on this winter. This is my 1st winter with the WK with a hemi. All fluids are topped up and current. But when I start her up after sitting overnight it makes a loud whinning sound that goes away after a couple of minutes. It only makes the noise after sitting overnight when its really cold.
Should I be concerned?
tok204 is offline
post #2 of 30 Old 12-23-2013, 11:44 AM
yzjwk
2005 WK
Wow , nice to see someone else from the area round here . Sounds like the power steeing pump . mine started doing that this year when i ran low on fluid ( guess i have a small leak to find in spring) . I topped up the fluid and it's better , but still makes the noise after the really cold nights . Start it with the key and turn the steering wheel when it makes the noise . If the noise changes or goes away , then that's your problem .
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #3 of 30 Old 12-23-2013, 12:09 PM
caulk04
2008 WK
I'd go with PS pump as well. I've never had temps that low, but have been in double digit negatives. Definitely noticed stiff power steering and can see the pump cavitating some as the fluid is too thick to flow properly at first.
A change of the fluid would likely help some.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is online now
post #4 of 30 Old 12-23-2013, 03:01 PM
colinzj
2006 WK
There's a redesigned reservoir available for just this problem on '05 and '06 Hemis:
http://wkjeeps.com/tsb/tsb_wk_1900905.pdf
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is offline
post #5 of 30 Old 12-24-2013, 11:24 AM Thread Starter
tok204
2005 WK
Hi yzjwk:
We have a house/cottage in Great Falls and my wife has family in LDB.
tok204 is offline
post #6 of 30 Old 12-24-2013, 11:25 AM Thread Starter
tok204
2005 WK
Thanks colinzj:
Printed out the TSB and am going to do some cross border shopping.
tok204 is offline
post #7 of 30 Old 12-24-2013, 02:39 PM
jediknight
2008 WK
CRD PS pump whining noise
Is your Hemi equipped with an hydraulic fan ?? ... I'm wondering if this is also an issue with the crd base model.
Mine is a crd (hydraulic fan) and is doing that PS whining noise after cold start up. It is low on fluid for some reason and fan is spinning very very slowly.
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is offline
post #8 of 30 Old 12-25-2013, 09:28 AM Thread Starter
tok204
2005 WK
Mine does have the hydraulic fan. I thought the fan hydraulics were powered thru the Power Steering pump as well?
tok204 is offline
post #9 of 30 Old 12-25-2013, 10:53 AM
BAH101
2008 WK
Originally Posted by jediknight
Is your Hemi equipped with an hydraulic fan ?? ... I'm wondering if this is also an issue with the crd base model. Mine is a crd (hydraulic fan) and is doing that PS whining noise after cold start up. It is low on fluid for some reason and fan is spinning very very slowly.
My CRD does that when cold. I think it is just cold fluid trying to go through the pump.
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #10 of 30 Old 12-25-2013, 01:20 PM
yzjwk
2005 WK
Originally Posted by tok204 View Post
Hi yzjwk:
Hey , that's cool . What a small world .
You are correct , The Power steering pump supplies the cooling fan .
ALL Hemi and CRD equiped WKs have the hydraulic cooling fan .
There is a flow control valve on the fan that opens and closes based on the engines various cooling needs and can make the fan turn anywhere from 150 rpm - 3000 rpm .
Keep that resevoir filled with the mopar only fluid , otherwise you stand a chance of getting too low and cavitating (getting air in) the pump .
Merry Christmas to All !
90 YJ Islander 4.2L
2010 MK Patriot
yzjwk is offline
post #11 of 30 Old 12-25-2013, 07:00 PM
jediknight
2008 WK
Good write up!
Filled her up with the mopar PS stuff, noise is almost disapeared or is barely audible and the fan is back on spining ... Gotta be carefull with the fingers folks, hydraulic fan eats everything on its way. Humm maybe I have a small leak somewhere I'll keep an eye on the reservoire until spring is back.
Merry christmas guys!
Thanks.
post #12 of 30 Old 12-26-2013, 08:17 AM
DarthJeep
2005 WK
My 05 4.7 does this on cold mornings. I just attribute it to the fact that Jeeps hate the cold weather lol. It goes away after the revs settle down.
Build Thread -
Black Wk Club 166
DarthJeep is offline
post #13 of 30 Old 12-26-2013, 09:19 AM
modernblueWK
2008 jeep wk 4.7
2010 hemi charger
2010 ford crown vic 4.6
2012 hemi charger
2013 hemi durango
All these do it when its been -10 all night.
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
post #14 of 30 Old 01-02-2014, 05:55 PM
Leeworthy
Your belts are cold and contracted hence why they make the noise. After they turn a couple times and stretch back out the noise goes way. Mine does it all the time in the winter. Has a brand new power steering pump and rack in it.
Always cold here in canada lol.
Leeworthy is offline
post #15 of 30 Old 01-02-2014, 06:44 PM
bigphil76
2005 WK
Its definitely the reservoir. I followed the tsb and mine hasn't made the sound since.. Changed it with radiator/waterpump. Better access
97 ZJ 4.0, 2005 WK Hemi, Khaki WK Club #50 !!!!!!!GO TAR HEELS!!!!!!!!
bigphil76 is offline
