Wife's 07 WK is having issues with power locks. None of the locks will respond to either the key fob or the driver's side door or passenger side door switch.
When hitting either the keyfob, driver's side, or passenger side I can hear a clicking noise from the somewhere in the dashboard on the driver's side.
Also not able to open the rear hatch because it won't unlock. Able to open the glass.
Checked the Wires running to the driver's and passenger's doors. Didn't see any broken like on her XJ (stupid speaker wires keep breaking)
Unplug the wiring harnesses for all the doors, replace the fuse and try it again. If it blows, the short is in the hatch or hatch circuit or the body side of the door harnesses. If it doesn't blow, reconnect the doors one at a time and keep testing until you find the one that pops the fuse.
The pictures in the parts diagrams aren't the best but it looks like the plugs are right after the rubber boots coming into the chassis, so I'd start with the kick panels up front and the lower pillar trim between the front and rear doors.
Maybe I was leaning that way. Or dust. Blew out the boots and plugs on both sides with the compressor. Wife says it is still working this morning so we will see.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
