no break light - JeepForum.com
post #1 of 8 Old 11-06-2011, 02:19 PM Thread Starter
jeeper5287
2005 WK
no break light
I have a 05 grand Cherokee limited and my drivers side break light won't work. The directional and the rear light still work and its on the same bulb as the break light. Can anyone help? I looked under and didn't see any broken wires or anything
jeeper5287 is offline
post #2 of 8 Old 11-06-2011, 02:20 PM
TurboDiesel
2008 WK
probably the bulb...
swap the bulb from the other side to test
TurboDiesel is offline
post #3 of 8 Old 11-06-2011, 02:32 PM
Tango.
2008 WK
That would be the bulb. There are different filametes in the buld for each function, and the filament for the brake light has gone out.
Tango. is offline
post #4 of 8 Old 11-06-2011, 02:34 PM
trax95008
2006 XK Commander
You have a light that tells you when to take a break?
trax95008 is offline
post #5 of 8 Old 11-06-2011, 04:43 PM
Budasac
2005 WK
Check your fuses if it's not the bulb. There is seperate fuse for each function in each tail light. There are five or six fuses total for the tail lights.
Budasac is offline
post #6 of 8 Old 11-06-2011, 06:50 PM Thread Starter
jeeper5287
2005 WK
I already checked the fuses and replacing the bulb was the first thing I tried
post #7 of 8 Old 11-06-2011, 07:03 PM
Budasac
2005 WK
How does the socket look? any corrosion or heat marks? Do you have a tester to check for power?
Budasac is offline
post #8 of 8 Old 11-07-2011, 03:38 AM Thread Starter
jeeper5287
2005 WK
All the plugs look good no corrosion or anything. Im going to grab a tester at work today and see if there's power
Break Light Issues (All won't Work) (1997) taraevanson ZJ Grand Cherokee Forum 7 12-04-2010 06:56 PM
Break Light Issues RyanWJ ZJ Grand Cherokee Forum 8 01-10-2010 03:48 PM
ABC Break Light is on ... mmstone ZJ Grand Cherokee Forum 9 10-22-2009 10:07 AM
96 JGC Break light on dash. Elkaholic ZJ Grand Cherokee Forum 6 06-23-2008 12:52 PM
99 WJ break light on? 02Lightning ZJ Grand Cherokee Forum 3 01-18-2006 09:24 AM
