Newbie question on Diesel Particulate Filters..???
#1 | |
Hi guys, i've just purchased my first Jeep Grand Cherokee... what a motor it is..very impressed so far,but i have a question on the diesel particulate filter...?? Do i have one ....its a 2005 55'plate 3.0 CRD Limited first registered in dec 2005.
Thanks in advance....
#2 |
I believe the dpf came out in 2007, at least thats the case for north america.
2008 WK "S" Limited bright metallic silver, 5 speed W5J400 transmission, June 18/2008 build, 213RE rear differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, 3.0L CRD. |
#3 |
Hi suzieque,
yes i've read that also but the diesel has been with the uk since april 2005, and i think it has the same engine so ......still un-decided, ok where could i look on the car to find the particulate filter itself and what exactly would i be looking for....??? Thanks for your reply... karl |
#4 |
Merlintec can verify this...but I am 95% sure the DPF is a North America feature because of EPA2007 emissions
#5 |
hi scootr,
You could well be rite, i've not found anything in my handbook that states i've got one......how can i send merlintec this question.....??? |
#6 |
Instead of the guessing game, get under there and take a look.
#7 |
Thanks for that toycarrier......but what exactly should i be looking for...ie...where is it and what would it look like....does it look similar to the catalyst......?????
#8 |
here are some photos of where the dpf is located on my 2008 WK 3.0L CRD.
#9 |
I tried to circle the dpf in the photo, still hard to see it because it sits low. also keep in mind that the photo is from a left hand drive jeep.
#10 |
Bought, not built.
The circled thing above is the catalyst (?).
The dpf is located below the passenger side seat. you can see the two fuel lines that feed it. ![]()
07 Steel Blue Overland CRD QDII | Bilsteins | 4xguard Matrix | Rear SRT8 SwayBar | DashHawk w/egt | GReddy Full Auto II Turbo Timer | Provent | MBRP XP Exhaust | New Intake Tube & Seal | Alternator Splash Guard | Crank Sensor | GPS AJ InMotion Hack | Fuelly.com - wookiee Blue WK Club Member #13 | 100,000 Mile Club | Dogpiled Club |
#11 |
#12 | |
As for the first picture it is a pre-catalyst, there is also the main catalyst further in line between the DPF and pre-cat.
2008 GC CRD, OME 2" lift kit, 265/70/R17 Cooper Discoverer S/T's, 1.5" Spidertrax spacers, gutted turbo resonator |
#13 |
#14 |
Hi
Correct they are pressure line the go to the pressure sensor you can see in the first picture. Karl our GC don't have DPF for some reason, only the 300c and Commander (with the same engine) does. Regards, Merlin
UK Chrysler Jeep Master Tec. |
#15 |
here is an article with some photos of the exhaust removal
2008 Jeep Grand Cherokee Exhaust Upgrade Stock Exhaust Photo I'm not sure this statement is true, or maybe its just not true with Canadian delivered CRDs.
2008 WK "S" Limited bright metallic silver, 5 speed W5J400 transmission, June 18/2008 build, 213RE rear differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, 3.0L CRD. Last edited by suzieque; 11-24-2009 at 05:50 PM.. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
