Newbie! I believe i trashed my transmission ;( 2006 cherokee 3.7 4x4 (awd) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Newbie! I believe i trashed my transmission ;( 2006 cherokee 3.7 4x4 (awd)
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! The Original 3/8" Ruffstuff Diff Cover!The Cure for your Tie Rod Roll!
Unread 08-19-2014, 09:45 PM   #1
Frivera5
Hi everyone, my name is jose from tucson az. jst joined a couple of days ago!
Im in need of some advice from you guys.
Long story short, i was camping outside town with the family and some friends, my cherokee had a injector leak which was real bad. At the moment i was freaking out because all the fuel on the engine and engine bay. It was getting dark and wanted to get home. Soo my friend and i pulled the jeep to the nearest gas station which was 6 miles. Came back the next day fixed the injectornleak but the transmission is not responding. Only now i know i cant pull an awd transmission. What should i do ? Anybody has seen this before ? Whats better jst replacing the transmission ? Repair it ?? maybe i trashed the transfer case too?
Thanks in advance! Flamee awayyy lol
Frivera5 is offline   Reply With Quote Quick reply to this message
Unread 08-20-2014, 09:37 AM   #2
Mikeb093
2008 WK
Was the transmission acting weird at all before you left it overnight? If not, was the gas station in a bad area? Maybe someone messed with it.
2008 WK, 3.7L, Silver with Tint, Blacked out emblems and Custom Grill mod. Lift coming soon...
Mikeb093 is offline   Reply With Quote Quick reply to this message
Unread 08-20-2014, 10:37 AM   #3
mkmk
2006 WK
Did you disengage the drive system with the lever next to the shift lever? That's what you're supposed to do when towing your Jeep.
mkmk is offline   Reply With Quote Quick reply to this message
Unread 08-20-2014, 05:22 PM   #4
yzjwk
2005 WK
As long as the transmission was in neutral , i can't see you doing any damage to that . Your transfer case output shaft is probably toast though .
You might have gotten away with towing it if you removed the front drive shaft ( the jeep will even roll with the transmission in park that way ) .
Guess you'll read the owners manual next time
no such thing on a 3.7/QT1 wk . single speed transfer case only .
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline   Reply With Quote Quick reply to this message
Unread 08-20-2014, 07:07 PM   #5
mkmk
2006 WK
Ah, oops. Sorry about that!
Best of luck sorting it out.
Unread 08-20-2014, 08:24 PM   #6
DeChache
2003 WJ
How fast did you tow it. I drug my 08 about a mile last summer in desperation with the transmission in neutral and its find 15,000 miles later.
His 2003 Limited 4.7 QD 145K
Hers 2008 Laredo 3.7 QT1 119K
DeChache is offline   Reply With Quote Quick reply to this message
Unread 08-21-2014, 05:36 PM   #7
Frivera5
My transmission was on neutral the whole time. Also it wasnt acting upor anything at all before the incident.. My question is could it be the transfer case ? And not tthe transmission ? I really have t check it all out. How can i check that put the tc shaft
Unread 08-22-2014, 08:15 AM   #8
Nejeep
Pull the tc drain plug and see what comes out, clean fluid or chunks of metal
06 Laredo - 4x4 V6 - Stone White - Custom LED Cargo Area Lights, Lighted Visors Added - now at 49k miles
97 Laredo - 4.0 4x4 Daily driver for 8 years then relocated to Arizona for 6 more years with the relatives
Nejeep is offline   Reply With Quote Quick reply to this message
