New to the site , what upp?! - JeepForum.com
post #1 of 11 Old 01-23-2013, 10:10 AM Thread Starter
SILV05HEMI
2005 WK
I got a 05 grand cherokee 5.7 limited n i got issues
cold start....
Reverse the rpm hops a lil when put in gear then almost stalls
drive same thing but will satll sometimes
drive up to a stop light n stop she stalls
stops after some driving n warms up
kinda sounds like shes hiccpuing/slight jerking when cruzing say at 50 and low rpm ....let her down **** then power theru the low rpms shes fine
someone told me it could be my throttle body or etc?
Hoping not the tranny or transfer case
anything will help
thanx
SILV05HEMI is offline
post #2 of 11 Old 01-23-2013, 10:13 AM
cheftrail
Welcome! try the Position sensor on the bell housing.
05 TJ locked & loaded, 04 WJ DD, 96 XJ and a darn Volvo V70
cheftrail is offline
post #3 of 11 Old 01-23-2013, 12:38 PM
bigphil76
2005 WK
I have a 05 wk hemi also.. and mine kinda studders at low rpm pulling a slight hill and sometimes flat land.. but when you give it more then a inch of throttle she purrs just fine.. I did some research and some people said EGR valve.. I got one just haven't replaced it yet. because I don't have anything to cut the wedged bolt off. and I also read that 87 octane can cause that to..
bigphil76 is offline
post #4 of 11 Old 01-23-2013, 07:50 PM Thread Starter
SILV05HEMI
2005 WK
Thanx
my gc dose the same thing also stalls at stops when first started
thanx for the info ...when i get money n time ill try it all out
any more info will be greatly apprecitaed
also info about ome hd lift, rola rack , 4xgaurd bush guard , tail light gaurds , rubican wheel n tire and where the best palce to buy
and trails in va i wanna get her dirty lol
post #5 of 11 Old 01-23-2013, 10:17 PM
trax95008
2006 XK Commander
The gas is a good point. Are you using 87, or 89 like the owners manual says to use?
trax95008 is offline
post #6 of 11 Old 01-23-2013, 11:31 PM
ca07wk
2007 WK
Look up member Kolak, not sure if he carries all of those but he has the best price on the OME.
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline
post #7 of 11 Old 01-24-2013, 11:43 AM Thread Starter
SILV05HEMI
2005 WK
Im using the highest grade gas from local gas station 89 or 93 octane or watever it is
post #8 of 11 Old 01-24-2013, 11:44 AM Thread Starter
SILV05HEMI
2005 WK
Good looks , thank you
post #9 of 11 Old 01-24-2013, 02:38 PM
RagtagGuy
2005 WK
The Hemi doesnt take 93. Stick to 89 or 87
RagtagGuy is offline
post #10 of 11 Old 01-24-2013, 04:09 PM
Skrimps
welcome!
Skrimps is offline
post #11 of 11 Old 01-25-2013, 10:29 AM Thread Starter
SILV05HEMI
2005 WK
Roger that , greatly appreciate it
