New owner here! 2006 w/5.7 Hemi - I have a strange rattle - JeepForum.com
post #1 of 7 Old 08-06-2013, 07:47 PM Thread Starter
funair85
2006 WK
Hi all.
My name is Joe. Nice to meet you all.
I purchased about a month ago a 2006 WK, 68k miles, pretty much in superclean condition.
I have an issue that I have tried to research on here and I am having difficulty finding an answer. I hope someone can help.
Right behind the latch (on the drivers side) that connects and secures the rear seat when in the up position, there is a rattle that sounds like it is coming from either behind the pillar trim or from under the trim of the very back window. It is really strange. I only hear this rattle when I go over a speed bump or something similar.
I do have new shocks on the rear if that makes a difference. I have gone around the shock and everything is tight.
I can almost swear it is coming from the inside?
Can anyone help? thanks!!!
funair85 is offline
post #2 of 7 Old 08-07-2013, 04:45 AM
BoraBora
2015 JK Wrangler
Did you check the torque? Check the heat shields. That was my problem, took me 2 weeks to figure it out and I was extremely frustrated...
'15 JK 2.5" lift on 35's
'06 WK 3.5" lift on 33's (Sold)
BoraBora is offline
post #3 of 7 Old 08-07-2013, 07:25 AM
yzjwk
2005 WK
Originally Posted by funair85 View Post
Hi all.
Does it still make noise if you have the rear seat down ?
I think i remember a while back someone here having issues with that seat latch causing a rattle . Something about the spring that closes the latch in maybe ??
good luck
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #4 of 7 Old 08-07-2013, 07:38 AM
Anon155
2005 WK
If the previous owner ever took the rear seat out, they may not have gotten it down in the right position. It uses a hooking type system that you have to get it into at the base of the seat. I had some sort of rattle back there when I didn't get it right once. It affected everything, even made it hard to latch the back of the seat correctly. The latch moved around more, never felt secure. If you have tools, I would try taking the back seat out and pop the rear panel where the latch is. It isn't hard to do, and I'll give you a link to a website that has great info for our jeeps. Especially on how to take them apart and put them back together. You may have something loose that just needs to be moved or torqued down. Good luck!
Here's the link:
http://www.wkjeeps.com/interior_trim.htm
05 Jeep Grand Cherokee: ORT 4X4; Khaki #55
Too many mod's to list...
Anon155 is offline
post #5 of 7 Old 08-07-2013, 08:41 PM
DRCracker
2006 WK
Hi all.
WOW, I have a 2006 WK Hemi and I have the exact same rattle.
It hasn't changed even though I have a new OME HD and the rear sway bar has been torqued down.
I concluded that the rear seat was rattling on it's latch, as in another thread.
I'd like to see if you find another explanation, I've been egnoring my rattle!
TC
MOLON LABE: 2006 WK Limited, Dark Khaki Pearl, 5.7 HEMI, QDII,
Console XDs-45acp, Billet Catch Can, Airaid CAI Tube,
1" Spacers, Steel Armadillo Sliders, Dark Khaki 4xGuard Front Skid,
Dark Khaki 2011 #9104 Wheels, Firestone Destination A/T 265/70/17's.
OME HD lift. Dark Khaki Matrix Brush Guard, Dark Khaki Painted Headlight Bezels.
Hemi Club #65 // Khaki WK Club #40
DRCracker is offline
post #6 of 7 Old 08-08-2013, 09:56 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
My seat latch in that location tends to make a rubbing or squeaking noise from time to time.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #7 of 7 Old 10-28-2013, 03:25 PM Thread Starter
funair85
2006 WK
thanks guys, it was the latch. I taped it up and it is good to go!
funair85 is offline
