new to me wk, cruise quit working on the way home - JeepForum.com
post #1 of 9 Old 10-24-2013, 04:14 AM Thread Starter
chance_p
2008 WK
Hey guys I just picked up a 2008 wk today. About 1 hr into my 6 hour drive home I shut the cruise off because of traffic. When I turned it back on the cruise letters pop up on the dash but it will not set. Im going to try swapping a fresh fuse tomorrow, but does anyone have any other suggestions? Im pretty disappointed that this has happened. Could I have changed a setting that would cause this? I searched but all the threads I found people said that their dash wouldn't display "cruise" when turned on, which is why I started a new thread.
08 WK 4.7 QTII - 4" Superlift - JK Moabs - 265/70 Cooper AT/3 - Flashpaq
chance_p is offline
post #2 of 9 Old 10-24-2013, 04:31 AM
Eastwk
2007 WK
I have to hit cruise then hit it again to set
Eastwk is offline
post #3 of 9 Old 10-24-2013, 05:15 AM
chrali
2006 XK Commander
Are your tyres evenly worn? My xh drops out of cruise as mine hadn't been rotated. I feel the jeep tugging as it thinks it's losing grip and I assume it's braking a wheel thus dropping out of cruise. When is really bad then the tcs light shows. If I disable the tcs I haven't a problem.
Encourage alternative fuels - use all the petrol!
GDE HOT Tune
chrali is offline
post #4 of 9 Old 10-24-2013, 05:51 PM Thread Starter
chance_p
2008 WK
CEL came on. Read codes.P0457, p2299, p0884n, c2100 (check gascap has been on since I bought it, but I was informed of this at purchase). I erased all codes and now cruise works again. From those codes, does anyone have a clue as to what caused my issue?
chance_p is offline
post #5 of 9 Old 10-24-2013, 06:13 PM Thread Starter
chance_p
2008 WK
Appears I could have applied the gas and brake at the same time causing the p2299 which can cause the cruise to stop engaging. Hope this helps someone
chance_p is offline
post #6 of 9 Old 10-25-2013, 04:46 AM Thread Starter
chance_p
2008 WK
Well it quit working again. No CEL. Gas cap/evap problem hasnt been fixed yet. Anyone have any ideas?
chance_p is offline
post #7 of 9 Old 10-25-2013, 11:23 AM
modernblueWK
Cruise doesnt work if there is a cel fault i think.
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
post #8 of 9 Old 10-25-2013, 06:02 PM Thread Starter
chance_p
2008 WK
Pulled codes today... none were found. Told my scanner to clear codes anyways. Cruise works again. What gives? Ive got an appointment to get my PCM flashed next week. Maybe that will help sort it out.
chance_p is offline
post #9 of 9 Old 11-02-2013, 11:48 PM Thread Starter
chance_p
2008 WK
Incase anyone finds this in search results... my vaccum purge solenoid was stuck causing BOTH of my issues. Hooked it up to a snapon computer, ran a purge test on the evap system, both issues immediately cleared up. The test must have put a little more pressure on the solenoid to unstick it.
chance_p is offline
