New Lift, Tire & Wheels - JeepForum.com
post #1 of 21 Old 10-03-2011, 06:13 PM Thread Starter
SamanthaAnn
2008 WK
Hey, I'm new to this forum and i was hoping someone could help me out. I have a 2008 Jeep Grand Cherokee and I want to get a lift anywhere between 2 and 3 inches and get a nice beefy tire with a nice set of wheels ..probably black.. I think I want off road tires, but I hardly ever go off roading.. so maybe there's a different tire i should be getting? I have NO idea what to get or where to go.. or what's even going to fit! I don't want to go to a place to get it done because I wasn't looking to spend THAT much.. i know someone who can do the lift but I want to be able to know what I'm talking about .. so if anyone has any suggestions please help!
SamanthaAnn is offline
post #2 of 21 Old 10-03-2011, 06:24 PM
Budasac
2005 WK
I would suggest you look through the Wheel and Tire thread and also the FAQ's.
Once you do you'll have a better idea of what the end result will look like with different combos. There's also a ton of info in the build threads which you can also find links to at the top of the WK page.
If you're not looking to spend alot of money you're going to want a Budget Boost like Rough Country or Daystar which will give you about 2" and allow you to fit 265/70/17 or 255/75/17 tires(with some mods). That's a pretty common set-up.
Budasac is offline
post #3 of 21 Old 10-04-2011, 09:06 AM Thread Starter
SamanthaAnn
2008 WK
Thanks so much! ..looking through the tire and wheel link def. helped me see how i want my truck to look. If i just did a 2 inch spacer .. would i feel a difference in the way it rides?
post #4 of 21 Old 10-04-2011, 09:07 AM Thread Starter
SamanthaAnn
2008 WK
ps your jeep looks sick!
post #5 of 21 Old 10-04-2011, 09:15 AM
DuncsJeeps
DuncsJeeps's Avatar
2006 XK Commander
The spacer lifts don't change the ride or handling. The only thing you might notice is that your center of gravity goes up (you'll lean a bit more in the corners)
DuncsJeeps is offline
post #6 of 21 Old 10-04-2011, 09:39 AM
AJeepZJ
2006 WK
Actually Buds pic needs to be updated in that list because he ditched the chrome (thank God).... Whenever you get a moment, Bud, can you post an updated pic (full body side-pic) of your WK in ur build thread...
aj
All Gear, No Skill.
AJeepZJ is offline
post #7 of 21 Old 10-05-2011, 06:31 AM Thread Starter
SamanthaAnn
2008 WK
Another quick question.. i already get 12 miles to the gallon.. is the 2 inch lift going to make it worse? If so.. should i just get the biggest tires the can fit without a lift? I don't know what to do!
post #8 of 21 Old 10-05-2011, 09:01 AM
AJeepZJ
2006 WK
The tires selection will affect your mpg far more than your lift... If you really want to lift and get tires... Stick to All-Terrains, keep your air-dam on, and don't put anything on your roof, keep your tires inflated properly, make sure you get those tires balanced and suspension aligned. Keep up with your air filter, and replace your 02 sensors according to the maintenance schedule.
All Gear, No Skill.
AJeepZJ is offline
post #9 of 21 Old 10-05-2011, 09:30 AM Thread Starter
SamanthaAnn
2008 WK
oh wow .. can't believe i didn't know that! See i learn something new everyday .. but what's an air-dam? and when or how would i know when to change my 02 sensor lol I obviously don't know anything about the car internally i just want to make it look nice!
post #10 of 21 Old 10-05-2011, 09:36 AM
DuncsJeeps
DuncsJeeps's Avatar
2006 XK Commander
The air dam is below the bumper...
With the airdam...
lift & tires front by kamileon50, on Flickr
Without the airdam..
perched jeep by kamileon50, on Flickr
post #11 of 21 Old 10-05-2011, 09:49 AM
paroxysym
2007 WK
if you got a tuner and adjusted your speedo and what not with it your MPGs would not be effected. im running 255s and a BB and see close to 19 on the highway and anywhere from 15-16 just cruising around, and thats on a 91 tune from a superchips flashpaq. as for tires, if youre not wheeling much id look into an all-terrain.
yes the BB will effect your ride alittle, depending how worn out your other suspension components are...
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #12 of 21 Old 10-05-2011, 03:49 PM Thread Starter
SamanthaAnn
2008 WK
your speaking like another language to me.. mind you i am a GIRL lol soo what the heck is a BB .. and where do i get a chip from! lol
post #13 of 21 Old 10-05-2011, 03:58 PM
stanton3
2007 WK
BB- budget boost aka a spacer lift.
What engine do you have? Superchips make tuners for the 4.7 and 5.7. Look around and search some more to get a better idea.
The lift will not hurt your mpg much, but the bigger tires will. Expect a couple mpg drop or more depending on how aggressive tires you go with. Any bigger/heavier tires are going to hurt your mpg.
Look through all the stickies and check out the build threads to get a better idea.
2007 WK 4x4 | OME HD 3" Lift | OME Shocks front + rear | 265/70/17 BFG All Terrains | 1.25" Wheel Spacers on stock wheels | Saguaro4xcomponents 5/8" Front recovery shackles | Aries Taillight Guards | PIAA 510 fogs in stock location | Midland 1001z Cb | Mopar Rear recovery hook | Rola Roof Rack |2 Hella 500ffs mounted behind grill | Firestick 3' Antenna | Saguaro Antenna Mount | Front Bumper Cut/Fender Trim | OEM Front suspension skid | 4xguard Front skid | Rusty's .5" Front Spacer | Lots more to come
Want to buy: 4xguard Rear Guard
stanton3 is offline
post #14 of 21 Old 10-05-2011, 05:09 PM Thread Starter
SamanthaAnn
2008 WK
5.7 L Hemi .. I'll def look into getting a chip, are they pricey?
post #15 of 21 Old 10-05-2011, 05:15 PM
stanton3
2007 WK
Research and see. Search on here for chips on the 5.7, there are tons of threads on them. See what best fits for you, most people like the superchips because it also offers a trans app.
stanton3 is offline
lift advice , off road , tires , wheels
WK with SRT wheels Tire question kosta104 WK Grand Cherokee & XK Commander Forum 2 07-21-2011 10:06 PM
Biggest tire for stock wheels with 6 inch lift worsrider4047 ZJ Grand Cherokee Forum 2 03-16-2011 10:33 PM
Tire size on OEM 5.9L wheels? WJOverland ZJ Grand Cherokee Forum 4 02-03-2010 02:46 PM
Tire bulges more with new wheels? Chiefwahoo ZJ Grand Cherokee Forum 15 11-01-2009 05:39 PM
tire sizes for 17 in wheels nsgrillo ZJ Grand Cherokee Forum 9 12-08-2006 01:59 PM
