New to the Jeep world..... please advise! - JeepForum.com
post #1 of 12 Old 07-07-2012, 06:42 PM Thread Starter
caiati
2006 WK
Hello All,
I joined this forum less than a month ago when I first got my Jeep. I love this thing but unfortunately I'm having some issues I was driving down the road normally a few days ago and when I went to step on the brake it seemed as if the ABS was activating unnecessarily. The road was dry and I was doing about 40MPH. I continued driving and a few minutes later it did the same exact thing. I pulled over and turned it off, waited a few minutes and started it again. It seemed to fix the problem for about 4 miles of testing the brakes. I came to a stop light and when the light turned green and I stepped on the gas it seemed as if the traction control started to activate. Then the ABS, ESP and Skid Marks light came on. It finally stopped and I was able to drive but the lights didn't go away. In addition the message center says "Service 4WD System". I again pulled over and turned it off and the message was still there along with the lights. Over the past few days it is intermittent and there are no extenuating circumstances to cause any of it that I know of. I searched the internet and this forum and see that there is a lot of this going on. I've read the fix were batteries being weak, ground connector on the transmission, wheel speed sensors, ABS sensors, re-flash at a dealer so on and so forth. Where do I start?? I just traded in a nightmare money pit of a vehicle and I'm praying I didn't inherit another....... Please advise where to start!!!!!
By the way it is a 2006 Limited with QTII if that helps. Before I bought it the front rotors and pads had been replaced by the dealer I bought it from. Also, are the speed sensors and ABS sensors everyone referred to the same thing? I hope to get some answers. Thanks in advance!!
Rob
caiati is offline
post #2 of 12 Old 07-07-2012, 08:38 PM
Chirpz
Chirpz's Avatar
2007 WK
Hmmmm..... that is a lot of lights. Add "Crank shaft sensor" to your list of possible causes. A failing sensor will cause the "check 4 wheel drive" error.
There was a rash of bad sensors. I had one on my 07 WK. But I did not have the other lights and problems along with it.
Chirpz
2007 WK CRD, Quadradrive II, OEM Tow Hitch, GDE EcoTune, DPF-Delete, 4xGuard Front, Rear, Belly Guards, Side Rails & Full Matrix, OEM Skids, EHM, Dash Duck.
Chirpz is offline
post #3 of 12 Old 07-08-2012, 06:35 AM
LJS8510
LJS8510's Avatar
2015 WK
I think wheel speed sensor.
2015 WK II 5.7 Overland, Offroad Group II,- 2008 WK Limited 3.0 CRD, - 2003 WJ Laredo 4.7, - 2001 WJ Laredo 4.0, - 1999 WJ Limited 4.7-
LJS8510 is offline
post #4 of 12 Old 07-08-2012, 06:38 AM
tom19511
2014 WK
First off, go to your local autoparts store and have them read the codes..From there you can start looking for problems.
Chirpz is right, these jeeps have bad crankshaft sensors. Dont go blindly into these problems, check the codes first.
Tom
tom19511 is offline
post #5 of 12 Old 07-08-2012, 06:42 AM Thread Starter
caiati
2006 WK
Thanks. How hard is this crank sensor to replace?
2006 Jeep Grand Cherokee, 4.7L V8, QTII, 2" Rough Country Lift, 265/70/17 Nitto Terra Grapplers, Magnaflow muffler w/ resonated tip
caiati is offline
post #6 of 12 Old 07-08-2012, 06:54 AM
tom19511
2014 WK
sensor
Not hard,
They are held in by a oring, they have a small wire harness attached to it.
On my 3.7 it was on the passenger side of the engine. Up there pretty far, so I had to reach a lot..
Also my '06 has a lot of surface rust around the hole so it took a lot of persuasion to pop it out, and a dremel with a sandpaper attachment to clean up around the hole to put in the new one. It was only 16.00, so it was worth it. Except I did it in February in my cold nonheated garage..
Tom
tom19511 is offline
post #7 of 12 Old 07-08-2012, 07:02 AM Thread Starter
caiati
2006 WK
So will an auto zone or advanced auto be able to locate the problem with a scanner or is this something the stealership has to scan?
caiati is offline
post #8 of 12 Old 07-08-2012, 07:43 AM
tom19511
2014 WK
auto zone or advanced auto will be able to locate the problem with a scanner
Tom
tom19511 is offline
post #9 of 12 Old 07-08-2012, 08:30 AM Thread Starter
caiati
2006 WK
Thanks guys
caiati is offline
post #10 of 12 Old 07-08-2012, 10:51 AM Thread Starter
caiati
2006 WK
So I drive the 15 miles to autozone and of course the lights weren't on when they scanned it. I drive all the way back home only to have the lights turn on 500 feet from my driveway!! I guess I'll have to make another trip soon. I did manage to have them check the battery while I was there and it was reading 100% so I guess I can alleviate that possibility.
caiati is offline
post #11 of 12 Old 03-05-2014, 02:29 PM
lazy-A
2006 WK
I am currently having the same problems. Let me know if you find anything out. Thanx.
lazy-A is offline
post #12 of 12 Old 03-05-2014, 02:32 PM
lazy-A
2006 WK
It's only engaging on drivers front side though, and feel grinding when I brake.
lazy-A is offline
new to the jeep world towdawg818 ZJ Grand Cherokee Forum 0 06-27-2012 08:08 PM
New to the Jeep world ZJPRKID ZJ Grand Cherokee Forum 1 11-20-2011 12:34 PM
What's going on everyone! New to the Jeep World! zwzj4life ZJ Grand Cherokee Forum 65 11-10-2011 09:44 PM
New to the Jeep world.... not to the forum world Jonhuff1987 ZJ Grand Cherokee Forum 2 02-21-2011 11:15 PM
New to the Jeep world deven84 ZJ Grand Cherokee Forum 6 04-06-2008 08:53 PM
