Need a parts list for mod. Ome - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Need a parts list for mod. Ome
Savvy/Currie Aluminum Control ArmsRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits ZONE 4.25" combo lift for TJ available at Rockridge4w
Unread 11-08-2014, 06:06 PM   #1
Eastwk
2007 WK
Ok so i am going to go modified ome. I currently already am running a rc bb with bilstein 4600 with mll f150. What else do I need to do this besides the springs
Eastwk is offline   Reply With Quote Quick reply to this message
Unread 11-08-2014, 08:13 PM   #2
jeepin_in_a_wk
2007 WK
Ome coils, I went with the hd ones in my 3.7, bilstien 5100 struts and 2" rear spacer.
jeepin_in_a_wk is offline   Reply With Quote Quick reply to this message
Unread 11-08-2014, 08:31 PM   #3
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
For starters you can't stack that Rough Country spacer on top of the OME springs up front. You need smaller strut spacers from Rusty's or RRO for example. The angles in the front end that a modified OME creates are already pushing the limits. You'll also want an adjustable rear trackbar. The OME HD rear springs by themselves start to push the rear axle to the driver side, ever so slightly, but add more to them and it gets more pronounced.
~Mike~
My Build Thread WK
My Other Build Thread XJ
'01 XJ with some stuff
Sept 2013 Cherokee of the Month
'07 WK with some other stuff
~RED WK CLUB #7~
'11 KK with mostly stock stuff
'06WK our first Jeep with stock stuff - totalled and gone
JeepN4KC is offline   Reply With Quote Quick reply to this message
Unread 11-08-2014, 08:42 PM   #4
jeepin_in_a_wk
2007 WK
Track bar is not needed but it's a nice thing to have. Mine is still centered with the stock one.
Unread 11-08-2014, 08:48 PM   #5
JeepN4KC
JeepN4KC's Avatar
You have HD OME springs out back with 2" spacers and stock trackbar and your rear axle is centered side to side?
~Mike~
My Build Thread WK
~RED WK CLUB #7~
Unread 11-08-2014, 08:53 PM   #6
jeepin_in_a_wk
2007 WK
Yes I believe so. If it's not it's off center ever so slightly it's not causing any problems
Unread 11-08-2014, 08:57 PM   #7
Eastwk
2007 WK
Yeah I know I take the spacer out of the front but don't you put in a 1/4 in rusty spacer instead to be mod. Or is that not nessacety
Unread 11-08-2014, 09:00 PM   #8
JeepN4KC
JeepN4KC's Avatar
Interesting. I noticed a considerable shift after modification.
........and I didn't use a full 2" spacer.
~Mike~
My Build Thread WK
~RED WK CLUB #7~
Unread 11-08-2014, 09:03 PM   #9
JeepN4KC
JeepN4KC's Avatar
Well the adjustable Bilstein struts will give you a bump without using the strut plates - but otherwise yes, the Rusty's or Rocky Road Outfitter's strut spacers are the way to go. The RRO is slightly thicker than the Rusty's and in my case, I didn't see how there was enough thread left on the strut bolts to go any thicker than the .25" Rusty's.
~Mike~
My Build Thread WK
~RED WK CLUB #7~
Unread 11-08-2014, 09:15 PM   #10
Eastwk
2007 WK
Yeah just put in the 4600 last year so I really don't want to row out more money on new struts
