Need help, Jeep won't start after attempting to use rear outlet - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Need help, Jeep won't start after attempting to use rear outlet
Rough Country Deals at JeepHut.comSave at JeepHut on Smittybilt Soft topsUp to $75 Cash Back on Your ARB Fridge Freezer Purchase
Unread 08-20-2014, 02:27 PM   #1
sshaughn
2008 WK
Hi everyone, I was attempting to use the rear outlet once the outlet button on the center console flashes a few times the car wouldn't start. When I turn the key everything on the dash comes on as normal but as soon as I try to start
It everything dies. Then I'll take the key out and try and again and the same thing happens again. Please help
2008 WK Overland 4WD CRD 3.0L, QD2, Green Diesel Engineering Hot-Tune, MBRP Exhaust, CB Engineering Turbo Resonator Delete Pipe, Kolak Addco Rear Sway Bar, K&N Air Filter, Propel Fuels B20 Biodiesel
sshaughn is offline   Reply With Quote
Unread 08-20-2014, 02:59 PM   #2
sshaughn
2008 WK
Never mind the car just started after about 15 minutes. The battery is only a year old so not sure what happened there.
Unread 08-20-2014, 03:02 PM   #3
sshaughn
2008 WK
Another Popping-clunking question
I am experiencing Popping-clunking somewhere on the mid to left side when turning left. Has been getting more frequent as of late. I have a skid plate on the bottom so not sure if the problem is under there. When the car is off I'll can turn the steering wheel back and forth and hear it as well.
Unread 08-20-2014, 03:03 PM   #4
sshaughn
2008 WK
Unread 08-20-2014, 08:26 PM   #5
ttusqrl
WK Supporter
2005 WK
I would not combine threads across separate topics. To answer your clunking question, it is probably your sway bar links -- the bushings wear out. It could also be your differential bushing, your upper sway bar bushing, etc. Get under the Jeep and have someone turn the wheel and see if you can find the clunk. There are a ton of threads on here about this (several on the first page even)
2005 WK Limited 5.7 ORT | OME HD | Saguaro Front Winch Bumper| Warn Zeon 10s | 17" Moabs w custom powder coat | 265/70/17 BFG TA KO | 1.5" Spidertrax | AIRAID CAI | Gibson 3" Exhaust | DiabloSport Intune | XD 5000K HIDs | JL Stealthbox w A1300 Amp | Valentine 1
WANTED (PM if Selling): Gobi Roof Rack, 4XG Armor, MyGig RHR & Lockpick, Catch Can, Rear Diff Cover, Weathertechs / Quadratec Mats
ttusqrl is offline   Reply With Quote
Unread 08-20-2014, 09:33 PM   #6
ChrisWK
2005 WK
Having same problem I ordered new links, but waiting for them I got under there and I tighten the bolts down it stopped the noise. Use a 18mm socket and torque them down
Limited HEMI Dark Khaki Pearl SRT8 Full Body Kit, Roof Rails,SRT8 Engine Strut Bar, Lund Rear Spoiler, MYGIG INSTALLED with LOCKPICK, Kenwood Sub,AFE Intake, Taylor Spark Plug Wires,G2 Silver Painted Brake Calipers, Billet Tech Catch Can, Addco Sway Bars Front and Rear, Eibach Lowering Springs,Xenon Volt HID Lows 6k,Chrome SRT Reps
ChrisWK is offline   Reply With Quote
