Need help identifying a diff - JeepForum.com
post #1 of 5 Old 07-25-2012, 08:03 AM Thread Starter
dtlemoine
2006 Grand Cherokee w 5.7 motor
Was originally thinking Dana 44 but the bottom of the cover doesn't seem to match the pics I've found online. The Chrysler 8.25 is close too, but again not a 100% match on what I've seen...
dtlemoine is offline
post #2 of 5 Old 07-25-2012, 08:20 AM
longboy
2006 WK
Looks like the Quadradrive axle (with the ELSD). If I remember correctly, it's a Chrysler 8.25 axle.
http://www.wkjeeps.com/wk_specs.htm#REARAXLE
2006 5.7l WK
longboy is offline
post #3 of 5 Old 07-25-2012, 09:09 AM
LordEnki
2006 WK
12 bolts = QDII 8.25
10 bolts = QT 8.25
06 WK Limited
Bright Silver Metallic
4.7L, QDII, Class IV hitch
245/65R17 BFG Rugged Trail T/A
LordEnki is offline
post #4 of 5 Old 07-25-2012, 09:46 AM Thread Starter
dtlemoine
Appreciate the responses guys! Seems like its the QD II 8.25 rear end. I understand this is a Chrysler 8.25 in a modified housing to accommodate the ELSD?
Getting a whine from the rear end at speed while on the throttle, disappears when off throttle. Thinking pinion bearing...
post #5 of 5 Old 07-25-2012, 09:48 AM
06WKHEMI
2006 WK
I have the exact same thing and I'll be taking mine in to get looked at
2006 Black wk overland HEMI QDII. OME HD bilstein struts with 58643 monroe load levelers RRO uca, afe cold air intake,hella 500FF behind grille, RC 1.5 wheel spacers s4xc cb antenna mount with 5ft firestik and midland 1001wx CB,265/70-17 falken rockymountain ats, pinch weld mod, door lock mod, Rola basket with 2 Hella 500 FF`s.
06WKHEMI is offline
need help identifying this richman10302 ZJ Grand Cherokee Forum 2 03-27-2011 11:57 AM
need help with switching stock rear diff for a limited slip diff jbearss04 ZJ Grand Cherokee Forum 4 09-02-2010 11:53 AM
Vari lok diff's in front open diff originalcapnron WK Grand Cherokee & XK Commander Forum 1 10-27-2009 09:47 AM
identifying a 5.9 lx2gt ZJ Grand Cherokee Forum 5 03-26-2009 11:55 AM
To rebuild a diff or not to repair a diff? Anto ZJ Grand Cherokee Forum 10 03-23-2009 03:13 PM
