need help with bad vibration - JeepForum.com
post #1 of 9 Old 08-11-2008, 05:05 PM Thread Starter
ryanlberg
2005 WK
so i have had my tires on for 2 weeks now and need help. i have a bad vibration when i hit 70mph. i don't get any vib at lower speeds just 70 and faster. now i know i will get a little vibration due to the fact that i have bfg mts but i have been other jeeps with the same tires and its not as bad. got a alignment when i put the tires on and this weekend i checked the wheel spacers and re torqued them to 90lbs and still got the shakes any one have any ideas please.
2005 WK 5.7 LTD
AEM
Flowmaster 50
superchips
HEMI Club Member #21
ryanlberg is offline
post #2 of 9 Old 08-11-2008, 06:01 PM
Texas WJ
Texas WJ's Avatar
2005 WK
Get them rebalanced.
Texas WJ is offline
post #3 of 9 Old 08-11-2008, 06:02 PM
Technojeep
I would recommend rebalancing them. I had same issue last year with my summer tires. I had them rebalanced this year before putting them on and it corrected the issue.
Technojeep is offline
post #4 of 9 Old 08-11-2008, 06:29 PM Thread Starter
ryanlberg
2005 WK
the tires have only been on for almost 2 weeks and i had them balanced when they got put on and the guy said he took his time to do them right maybe BS not sure.
2005 WK 5.7 LTD
AEM
Flowmaster 50
superchips
post #5 of 9 Old 08-11-2008, 06:42 PM
Texas WJ
Texas WJ's Avatar
2005 WK
It's cheap and easy to double check them at a shop before jumping into more involved trouble shooting. Losing a tire weight happens.
Also, if you've been in mud check the inside of the wheel to see if it's caked on. I've had mud throw off the balance till it was pressure washed off.
Texas WJ is offline
post #6 of 9 Old 08-11-2008, 06:48 PM Thread Starter
ryanlberg
2005 WK
well i guess i will start with that maybe at a new shop. i have yet to get her off road. thanks
2005 WK 5.7 LTD
AEM
Flowmaster 50
superchips
post #7 of 9 Old 08-11-2008, 07:24 PM
steve06hemi
2006 WK
going through same thing myself right now with pirelli scorpion ATR's. A normal balance machine will not work on some of the wk wheels. Apparently there is a piece of plastic that prevents the wheel from going all the way up on the machine. You have to find a shop that has the correct arm on it that actually has the studs on it. they then slide your wheel/tire on the 5 studs and tighten those down. If the shop you had it done at doesn't have the machine, they should reimburse you if you go somewhere that does. hope that helps.
steve06hemi is offline
post #8 of 9 Old 08-11-2008, 09:23 PM
rwmorrisonjr
2006 XK Commander
Make sure your spacers are hub centric, if they aren't then you'll get the vibration. I'm having the same issues with my wheels, getting them swapped out this week for hub centric ones, that should cure the problem.
rwmorrisonjr is offline
post #9 of 9 Old 08-12-2008, 03:57 AM Thread Starter
ryanlberg
2005 WK
they are hub centric. i guess i will get them rebalanced at the dealer.
2005 WK 5.7 LTD
AEM
Flowmaster 50
superchips
vibration rmtomasin ZJ Grand Cherokee Forum 11 03-26-2009 09:40 PM
vibration driabyor ZJ Grand Cherokee Forum 5 06-23-2005 09:24 PM
I6 vibration... CBlakeNS ZJ Grand Cherokee Forum 13 04-20-2005 09:43 PM
Vibration at 65+ MPH ats1968 ZJ Grand Cherokee Forum 1 02-12-2005 11:15 PM
vibration 01grander ZJ Grand Cherokee Forum 3 01-18-2005 07:34 AM
