Need Help: 5.9 Limited Starting Issue - JeepForum.com
post #1 of 3 Old 04-14-2010, 06:00 PM Thread Starter
bradtabor
My Jeep was driving fine and just died on me. Then when ever it would warm up it would die again.. I noticed I had no fuel pressure with I checked it at the rail.
I originally figured Crank Sensor, until it wouldn't even start when it was cold. Then I figured Fuel Pump.
So I replaced the fuel pump. Still no fuel pressure and it doesn't even kick on.. However the Relay is still good in the fuse box and even tried a known working one..
Also there is power going to the hot leads of the relay connection in the fuse box when the relay is removed and has the full 12 volts plus just like it should.
I also cleared the computer as well..
Can a bad Crank Positioning Sensor cause a fuel pump not to turn on???
Any Ideas??
bradtabor is offline
post #2 of 3 Old 04-14-2010, 07:13 PM
bobs68bird
1979 CJ7
A few years ago I fuel issue with a chevy had power ,good pump ,and relay mine turned out to be a oil pressure switch wire shorted. try looking in a wire diagram. Also if your pump is in the tank check the tank harness. I had a bad plug on my pump on my truck. Just some ideas. Good luck.
bobs68bird is offline
post #3 of 3 Old 04-14-2010, 09:48 PM
Texas WJ
Texas WJ's Avatar
2005 WK
Try the ZJ/WJ section, you're currently in the WK ('05- ) forum.
265/70-17 BFGoodrich All-Terrain T/A KO, 2" lift, JK Wrangler Moab wheels, Spidertrax Spacers, Rola Roof Rack.
Texas WJ is offline
cps , crank positioning sensor , fuel pump , starting
94 gc limited radio issue/steering issue? r34civic ZJ Grand Cherokee Forum 7 01-04-2010 06:00 PM
Starting issue. neoncrazy101 ZJ Grand Cherokee Forum 2 11-16-2009 07:54 PM
Starting issue stageninja ZJ Grand Cherokee Forum 4 02-13-2008 03:23 PM
starting issue zaq123 ZJ Grand Cherokee Forum 3 03-07-2007 07:02 PM
Trouble starting my 95 GC Limited! nholmes11 ZJ Grand Cherokee Forum 2 09-14-2001 10:01 AM
