Need Help with an 05 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Need Help with an 05
UCF Memorial Day Savings... Save 15% today!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Axles at CCOR
Unread 04-28-2015, 07:00 PM   #1
nyyankee
I'm looking to purchase an 05 GC w/ 72K and the steering wheel is worn at the 12'0clock and the drivers seat has a slight tear on the sliding in and out of the vehicle.
Is this an easy fix? Do I have to replace the whole steering wheel? How about the seat? Can an upholstery shop do this?
nyyankee is offline   Reply With Quote Quick reply to this message
Unread 04-28-2015, 08:57 PM   #2
whitejc4
2006 WK
Both can be fixed. I have both the same problems. Not sure on repair costs but I know others have had it done. Seems like some people do steering wheel skins/covers and others opt for trim shop work.
whitejc4 is offline   Reply With Quote Quick reply to this message
Unread 04-28-2015, 10:25 PM   #3
nyyankee
So a shop that does interiors would do the wheel also?
Unread 04-29-2015, 10:41 AM   #4
sheepdog918
2007 WK
Instead of paying extra for the steering wheel just wrap it in para cord, it's becoming more popular and looks pretty good too IMO. But yes an upholstery shop should be able to do both
There are the wolves, there are the sheep, but then, there are the Sheepdog's
sheepdog918 is offline   Reply With Quote Quick reply to this message
Unread 04-29-2015, 12:28 PM   #5
RCS1300
2005 WK
If funds are tight you can use vinyl adhesive with color match to fix the seat. I did mine. For the steering wheel, you can purchase a new one at moparpartsdiscounted for a few hundred dollars. You may need to email them directly with your color and trim details.
Most important is to check that the oil changes were done every 3,000 miles. Seek proof.
RCS1300 is online now   Reply With Quote Quick reply to this message
