Need a bit of help with transmission breather hose for a WK CRD - JeepForum.com
post #1 of 6 Old 12-09-2011, 03:47 PM Thread Starter
suzieque
2008 WK
Was installing a new skid plate and noticed a black breather hose from the back of the transmission to the engine compartment.
The engine compartment end is melted, like it was on the exhaust manifold.
Not sure how it happened, but I suspect the end of the hose should be tied to something in the engine bay, but not sure where.
Can one of you WK CRD owners tell me where the transmission breather hose should attach to and should the hose just be wide open or does it have some sort of cap on the end?
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #2 of 6 Old 12-09-2011, 03:58 PM
Tango.
2008 WK
One end is on the transmission and the other has a plactic breather cap on the end.
Tango. is offline
post #3 of 6 Old 12-09-2011, 04:30 PM Thread Starter
suzieque
2008 WK
ok, thanks! and the end with the breather cap is not taped or cable tied to anything?
suzieque is offline
post #4 of 6 Old 12-09-2011, 07:51 PM
SSF556
2008 WK
I believe it should be clipped to the passenger side area near the coolant tank.....I moved mine over the drivers side....or cool side of the engine.
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #5 of 6 Old 08-17-2013, 11:44 PM
jpm6621
I see this is an old post but im having problems with my transmission breather vent leaking out fluid. It's always been tucked up near the throttle body, has a white plastic cap on the end. Really don't know why fluid should be coming out of it. It leaked onto the hot engine one day and the fluid caught fire for a minute.
jpm6621 is offline
post #6 of 6 Old 08-18-2013, 09:28 AM Thread Starter
suzieque
2008 WK
I have not seen a fluid leak from my transmission breather hose. I did have a fluid leak on the front differential breather tube, i blamed that on the dealer for not fully filling the front differential and so the fluid was overheating. I drained and fully filled the front differential and all was well.
suzieque is offline
Oil breather hose Timon ZJ Grand Cherokee Forum 3 06-09-2011 07:49 AM
Transmission Breather Vent. sadass ZJ Grand Cherokee Forum 0 10-27-2009 10:48 PM
Front Diff Breather Hose torn off '94 grand cherokee 5.2 V8 BFI ZJ Grand Cherokee Forum 103 08-18-2008 09:17 AM
breather hose smokestack ZJ Grand Cherokee Forum 3 09-06-2007 01:41 PM
transmission hose Casper4x4 ZJ Grand Cherokee Forum 7 06-13-2007 03:01 PM
