Need advice on tire size with OME HD lift for mall crawler Commander - JeepForum.com
post #1 of 6 Old 01-19-2013, 06:54 AM Thread Starter
norwaywj
2006 XK Commander
Hello, I have an 2006 Commander Lim Hemi with QD2.
I'm adding the OME HD springs and shocks. This gives me 2" lift as far as I know.
I want to add MT Baja MTZ in 285/70/17, does anybody know if this will fit without mods on a mallcrawler ? Would I need spacers ? and if I do, will the wheels stick out of the fender flare ?
I would guess the MTZ are "bigger" than most 285/70/10 tires becuase of the pattern ?
I live in Norway, so I have to import the tires and its very expensive , so I want to make sure they will fit.
norwaywj is offline
post #2 of 6 Old 01-19-2013, 07:38 AM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Just stick with 265/70/17's
They're the best fit all around IMO.
285's will work but I'd go with 265's.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #3 of 6 Old 01-19-2013, 07:44 AM
silentj
2006 XK Commander
I agree with JeepN4KC. 265's are a great option for the 2" lift. I have 255's on my 2" lift and they still rub a bit.
06' XK 3.7 - RC 2" Lift | Hypertech Max Energy 52001 | Bilstein HD Front & Rear Shocks | Hankook DynaPro ATM 255/70R18 | 18" Sahara wheels | Spidertrax 1.5" Spacers | Rola Basket | Smittybilt D-ring Tow Hitch | 4XGuard Matrix | Hella 500's
silentj is offline
post #4 of 6 Old 01-19-2013, 08:38 AM
trax95008
2006 XK Commander
The HD springs will actually give you 3" in front and 2" in rear
trax95008 is offline
post #5 of 6 Old 01-19-2013, 09:15 AM Thread Starter
norwaywj
2006 XK Commander
Thanks for the input on both the OME and the tires. 265/70/17 is about a 32" tire I guess. Maybe that is a better option.
norwaywj is offline
post #6 of 6 Old 01-20-2013, 05:45 PM
sniezur
2007 XK Commander
I got just over 3" of lift in the front on my 2007 Commander Limited with the OME HD lift plus the Rusty's 1/4" spacer. I am gong to be installing either 275/70-17 or 285/65-17 tires. At full steering lock with 265/65-17 Wilderness A/T's with 1.5" wheel spacers I have less than 1/2" clearance to the rear wheel house inner plastic fender to outer edge of the tire. These tires are just over 30.5" in diameter so anything much larger than 31.5" will rub a bit under full lock.
The 275/70-17 Cooper AT-3's are just a hair over 32" diameter and the Yokohama Geolander A/T-S tires are 31.75" diameter.
sniezur is offline
