Nav update disk - JeepForum.com
post #1 of 5 Old 04-27-2013, 04:15 PM Thread Starter
RFisher
Nav update disk
I am thinking about buying a Nav update disk from Ebay. This one is for a commander, I have Grand Cherokee RER 2008. Seller has a vin number from his totaled out 2009 commander. Can someone confirm if this would install properly on my unit?
RFisher is offline
post #2 of 5 Old 05-10-2014, 01:46 PM
pastenseverb
2014 WK
What did you end up doing? I’m in the same boat.
pastenseverb is offline
post #3 of 5 Old 05-10-2014, 03:48 PM Thread Starter
RFisher
After much research, I found out that you have to buy the update from Navteq. The VIN number is written into the update disk. When you go to load the software CD, it ask for the VIN number, and everything most match what is on your unit. So if you buy something off of ebay, it will not work this I am sure of.
RFisher is offline
post #4 of 5 Old 05-10-2014, 05:18 PM
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
Originally Posted by pastenseverb View Post
What did you end up doing? Iím in the same boat.
The 07 version doesn't need a vin
07 Steel Blue Overland CRD QDII | Bilsteins | 4xguard Matrix | Rear SRT8 SwayBar | DashHawk w/egt | Provent MBRP XP Exhaust | New Intake Tube & Seal + EHM | Alternator Splash Guard | Crank Sensor | GPS AL InMotion Hack | Swirl motor bypass | Blue WK Club Member #13 | 200,000 Mile Club | Dogpiled Club | pre-N23 FDCM |
89 GW w/plow
wookiee is offline
post #5 of 5 Old 05-10-2014, 08:57 PM
CavallinoRed
2006 WK
Same with my '06. Picked up a DVD update off of eBay and install was quick and easy.
CavallinoRed is offline
