Nav System - JeepForum.com
post #1 of 9 Old 02-27-2008, 12:28 PM Thread Starter
Jmar8
Nav System
I just bought an '05 Limited with the Nav system, but it's missing the disc. I bought the vehicle at auction and "borrowed" a disc from another '05, but I couldn't get the disc to work so I put it back. What is the best source for the disc I need? Is there a difference between the software disc & the update disc?
Also, how does the system receive updates? Is it necessary to keep buying new discs to get the most current info?
Thanks for any info you might have.
Jmar8 is offline
post #2 of 9 Old 02-27-2008, 02:24 PM
merlinTec
merlinTec's Avatar
Hi
Unless yours are different to ours yes you do have to keep buying discs and the upgrade discs and software discs are the same thing.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #3 of 9 Old 02-27-2008, 03:33 PM
07WKLtd
2007 WK
Navteq released the most current version 'AF' about a week ago. You can buy the disc from them and it will have the most current software and map data.
I can't imagine why the disc you 'borrowed' didn't work - it's possible that there is a problem with your nav unit.
07WKLtd is offline
post #4 of 9 Old 02-28-2008, 08:06 AM
airportdave
2010 WK
Starting with the AD version of the disc (I think), discs are not backward-compatible. If you've loaded an AD, AE, or AF version into your Nav, you can't go back and use a previous version disc- destination entry and several other features won't work if you do. I just loaded the AF into my GC, and have noted several map/street/business updates in my area of Colorado, including (at last!) the correction of a 1/4 mile location error of all of the streets in my town. I haven't noticed any functional changes.
2010 Grand Cherokee Limited Hemi Q-D II, OME MD, 265/70/17 Hankook ATM's, HemiFever Tune
airportdave is offline
post #5 of 9 Old 02-28-2008, 12:15 PM
07WKLtd
2007 WK
I think you are on the right track, but not 100% correct.
As I understand it, starting with the AE disc, the firmware can not be reverted to a previous version by inserting the disc. Meaning that if you insert an AE disc, then insert an AD disc, it will not load the firmware from the AD disc.
That being said, you should be able to use an older disc in a unit that has newer firmware - you'll just have older map data.
07WKLtd is offline
post #6 of 9 Old 02-28-2008, 12:56 PM
airportdave
2010 WK
After I installed the AE disc in the REC radio in both my Durango and my GC, I inserted the older AD disc, and the map and POI data and did not work. After putting in the older AD disc, the unit showed and updated the moving map display, but the unit didn't have full functionality. When I attempted to enter a destination, none of the entry options (city, state, phone number, place type/name, etc.) were available, at least in my two REC units. WK- have you actually tried reverting to an older disc with a different result? My interest is piqued because I've been selling my old discs since they no longer worked for me. If so, maybe you have a newer version REC radio.
post #7 of 9 Old 02-28-2008, 03:19 PM
07WKLtd
2007 WK
I'll certainly defer to your actual experience doing it, as I've only read about it.....
Although, the App Ver on AE was 02.04.00. My REC came from the factory with 02.05.10 loaded onto the unit itself, but had a standard AE disc for map data, etc. Upon examination of the AE disc, it contained the 02.04.00 code. So even though my unit had a newer version of code than what was on the disc, it worked fine.
07WKLtd is offline
post #8 of 9 Old 02-29-2008, 07:13 AM Thread Starter
Jmar8
Thanks to everyone for your replies. I have ordered the newest version (AF) from navteq, and I have my fingers crossed. I tried going to 2 dealerships to borrow a nav disc from a pre-owned GC on the lot (just to verify the nav system is functional, but of course no one is interested in my problems, they just want to sell me a $300 disc.
I should probably post a new topic, but I'm wondering if my REC is Sirius satelite capable. I have the main owners manual, but no supplement versions that the manual refers to. Are all REC's capable, or is there an easy way to tell if mine is?
Thanks again
Jmar8 is offline
post #9 of 9 Old 02-29-2008, 08:08 AM
airportdave
2010 WK
Thanks again
All REC's are Sirius capable. If you get the factory Mopar Sirius kit, it is a direct plug into the back of the REC radio, and the screen will display song, artist and channel info. I added the REC radio and factory Sirius set up to my GC after I purchased it. It's all plug and play- the whole install took maybe two hours. I got my Sirius kit from Just for Jeeps dot com.
The hardest part of the install was getting up the courage to drill the 3/4" hole for the antenna in the roof of my brand new Jeep!!
Service 4x4 System AND Service Electonic Brake System...? TatorTodd WK Grand Cherokee & XK Commander Forum 0 12-25-2009 08:49 PM
PA System? GCL06 WK Grand Cherokee & XK Commander Forum 7 09-22-2009 09:57 PM
new system cfb3001 ZJ Grand Cherokee Forum 7 10-07-2005 02:57 PM
How do I get Vehicle Entertainment System turned on in my Nav system? JeepSam ZJ Grand Cherokee Forum 10 06-03-2005 03:46 PM
WJ: Which 4x4 System Is Right For Me??? ICanTowYou WJ Grand Cherokee Forum 2 05-02-2004 07:34 PM
