NAG1 High Mile, Filter Change? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > NAG1 High Mile, Filter Change?
Free shipping on Rugged Ridge XHD bumpersBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 01-19-2015, 09:13 AM   #1
BrooklynWK
2005 WK
212k on tranny about that time for another filter change, worth doing or at this point don't mess with it? Shifts fine no issues whatsoever
BrooklynWK is offline   Reply With Quote Quick reply to this message
Unread 01-19-2015, 11:10 AM   #2
johnniebravo
2008 WK
If you have been keeping up with maintenance, change the filter. There is no reason to stop now.
2008 CRD GC
johnniebravo is offline   Reply With Quote Quick reply to this message
Unread 01-19-2015, 12:22 PM   #3
BrooklynWK
2005 WK
I had the filter done around 100K and the plug. Doing anything to a high mileage tranny makes me nervous to say the least.
Unread 01-19-2015, 12:40 PM   #4
tom19511
2006 WK
I would change it. Couldnt hurt. If its gonna fail it will either way.
Tom
tchristopher1@wowway.com
2006 G.C.65th Anniv. Edition
2007 Liberty Sport 3.7
tom19511 is offline   Reply With Quote Quick reply to this message
Unread 01-19-2015, 04:31 PM   #5
10Xk
2010 XK Commander
112k since last change. Leave it alone, it works and odds are it will have issues after the fluid change.
10Xk is offline   Reply With Quote Quick reply to this message
Unread 01-19-2015, 08:40 PM   #6
caddydaddy
2007 WK
If your engine ran fine with a lot of miles on the oil, would you leave the oil in there? No, you'd change the oil and filter! Do the same for your transmission! Why does everyone get so scared over transmission maintenance?
2007 CRD Grand Cherokee Limited 4x4
GDE ECO Tune, Turbo Resonator Delete, EHM
170,000+ miles!
caddydaddy is offline   Reply With Quote Quick reply to this message
Unread 01-19-2015, 08:44 PM   #7
10Xk
2010 XK Commander
Transmissions function different that engines that why people tend to leave neglected transmissions alone.
Unread 01-19-2015, 08:56 PM   #8
caddydaddy
2007 WK
Both need clean fluid and filters for longevity.
170,000+ miles!
Unread 01-20-2015, 01:23 PM   #9
luckyse7ens
2010 XK Commander
This is wrong...
The issues arise with improper fluid/fluid level, and Forced flushes. Drop the pan, replace the filter and the fluid in the pan.
A couple more pan drops when convenient should replace all of the fluid.
Black WK Club #152
luckyse7ens is offline   Reply With Quote Quick reply to this message
