MyGig Navigation install in 2005 Grand Cherokee - JeepForum.com
post #1 of 13 Old 06-01-2013, 09:51 AM Thread Starter
bmcginnis
2005 WK
I am wanting to install a MyGig navigation system into my GC. I have the Limited which came from the factory with the UConnect hands free already installed running through the rear view mirror.
I have been looking around and found a RER or RHR model that some guys have installed into their rides.
Does anyone have any input as to what I should do? I don't want to put an aftermarket unit from like Best Buy in my Jeep, I want it to be a Jeep factory product.
bmcginnis is offline
post #2 of 13 Old 06-01-2013, 12:03 PM
sickchilly
2010 WK
Contact these people, they won't steer you wrong:
http://www.oemautopartsco.com
2010 Brilliant Black Crystal Pearl Coat Grand Cherokee S-Limited with various bits 'n pieces... broken in but not even finished!
sickchilly is online now
post #3 of 13 Old 06-01-2013, 12:28 PM
Billybcpt
2005 WK
Check out my Mygig install thread:
http://www.jeepforum.com/forum/f67/m...alled-1393534/
I actually just replaced the RER with an RHR recently but the install is the same, hope this helps!
Billybcpt is offline
post #4 of 13 Old 06-01-2013, 01:55 PM Thread Starter
bmcginnis
2005 WK
Billy
Did your Jeep already have a navigation screen system though?
post #5 of 13 Old 06-01-2013, 02:07 PM
Billybcpt
2005 WK
Yes the REC model. But I don't think that makes a difference.
post #6 of 13 Old 06-01-2013, 04:19 PM
Ben824
1997 XJ Cherokee
I put the RHR in my Dad's 06 Limited that had the REC. The MyGig is amazing! I will add this, while extremely rare, the RHR can have issues when installed in an 05-07 WK with the LockPick Adapter kit. CoastalETech does not officially support the RHR model MyGig. The highest model they currently support is the RER. I welcome those who beg to differ to give them a call to verify. OEMAutopartsCo will say it works fine but they do not make the product, CoastalETech does. And it will work fine, sometimes. I am having issues with my install and have been in contact with Carlos, there tech advisor for Chrysler products and we have been working with their R&D department and they say my symptoms are similar to the ones RER users were having before they added the software support for that radio. They are working on a software patch that should be out in the next month or so and that will add the RHR to their list of supported devices. This software patch will clear up any issues that users, like me, were previously having with this radio installed using their adapter kit.
The RHR is worth the money and the wait for the bluetooth streaming!
Ben824 is offline
post #7 of 13 Old 06-01-2013, 10:57 PM Thread Starter
bmcginnis
2005 WK
The model I have been looking at is the RHR, but my concern is that I have only the factory AM/FM/6-Disc in my Jeep, so will I run not more issues since my UConnect is run through my mirror, etc?
post #8 of 13 Old 06-01-2013, 11:17 PM
Billybcpt
2005 WK
Dude actually read my install thread, you just need to get a new Mopar Uconnect mic (it will work) as your mirror with Uconnect functionality will not work and definitely get the RHR! I've had ZERO, I repeat ZERO issues with my RHR/Lockpick combo in my 2005 WK Hemi. Everything works flawlessly! Bluetooth audio streaming, Uconnect, backup cameras, etc. Just do it and ignore any other negative input. If you have any issues associated with the install, feel free to PM me or even call me if you need to. No worries just do it!
post #9 of 13 Old 06-01-2013, 11:18 PM
Ben824
1997 XJ Cherokee
There is a small chance you might face the same problems I am having but it is rare and should be fixed with the new software update. Your current Uconnect system is run by a separate module in the Jeep from the Radio that handles all of that system. The RHR has a Uconnect module built into the radio so your old module will no longer be used. You will not need to do anything to disable it, it will just not be used in the new wiring harness. Your current Uconnect mirror however will not work with the MyGig so you will need to either purchase the new MyGig Uconnect compatible mirror (which is expensive) or you can purchase an inexpensive compatible microphone from a supplier like OEMAutopartsCo.
Ben824 is offline
post #10 of 13 Old 06-03-2013, 09:51 AM Thread Starter
bmcginnis
2005 WK
Anyone know where I could get the LockPick adapter for less than $285?
post #11 of 13 Old 06-03-2013, 10:19 AM
Ben824
1997 XJ Cherokee
That is the going rate. You may luck out and find someone here selling a used one or try ebay or amazon and you might get lucky there too.
Ben824 is offline
post #12 of 13 Old 06-03-2013, 10:21 AM
Billybcpt
2005 WK
Again read my thread. Solidsignal.com for $199. Make sure you get the adapter version not the regular v.5 Lockpick. Better yet here's a link:
http://www.solidsignal.com/m/product...tion-lockpicks
post #13 of 13 Old 06-03-2013, 07:14 PM Thread Starter
bmcginnis
2005 WK
Thanks!
grand cherokee , navigation system
