My remote (to unlock the doors) does not work - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > My remote (to unlock the doors) does not work
Poison Spyder from CCOR!HMF Fabrication 50" Light Bar Mounts for CJ/YJ Made IIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 02-10-2007, 11:46 PM   #1
cliff
My remote (to unlock the doors) does not work on my regular set of keys. I think the battery is dead. Not real sure. My second set of keys works great.
Anyone ever replace the battery on a remote?
Before I tear into it and break something, I thought I some of you may have some words of wisdom and experience. Also where did you get your battery? And how much was it?
Thanks
Cliff
cliff is offline   Reply With Quote
Unread 02-11-2007, 06:38 AM   #2
T-Rated
Here's what wkjeeps.com says:
Transmitter Battery Service
The recommended replacement battery is one CR2032 battery
NOTE: Do not touch the battery terminals that are on the back housing or the printed circuit board.
1. With the transmitter buttons facing down, use a small screwdriver or similar flat object to pry the two halves of the transmitter apart. Make sure not to damage the rubber gasket during removal.
Separating Transmitter Halves
2. Remove and replace the battery. Avoid touching the new battery with your fingers. Skin oils may cause battery deterioration. If you touch a battery, clean it with rubbing alcohol.
3. To reassemble the transmitter case, snap the two halves together. Make sure there is an even "gap" between the two halves. Test transmitter operation.
My comments: The CR2032 battery is widely available. I get my batteries from OSH. WKJeeps also states that the battery is supposed to last a minimum of 3 years.
T-Rated is offline   Reply With Quote
Unread 02-11-2007, 10:29 PM   #3
cliff
Thanks for your help. My WK is an 05 so it is probably about time.
Hate to sound totally dumb, but where is OSH?
Thanks
Cliff
Unread 02-12-2007, 07:08 AM   #4
T-Rated
OSH (Orchard Supply Hardware) is a Home Depot-ish chain owned by Sears.
Unread 02-12-2007, 08:58 AM   #5
drewman141
Gas Guzzler
drewman141's Avatar
1994 ZJ
It is probably much easier to get them at Radio Shack. Also Eckerd, Wallgreens or CVS will probably have them on that battery carousel thing.
2008 WK Overland HEMI - Modern Blue Pearlcoat
Fully loaded with slush mats of course.
MUST GO! 1994 Limited ZJ 5.2L V8 - Light Driftwood Satin Glow
It's a 94 5.2L Limited - trxus 33's on 15x7 steelies, 4.56s w/ front OX and rear trutrac, NP242 swap, novak shift kit, Kevin's ultimate 4.5" lift + ACOS, ARB front bumper w/warn M8000, rear tomkin machine bumper w/ tire carrier, kevin's hardore railz, kevin's ultimate tc skid, kevin's trackbar conversion, rusty's gas skid, flexalite efan, Kolak's performance ignition and brake upgrades. ViAir OBA, custom storage/sub box and I'm sure there's a bunch of other things I'm missing. Everything is a little over 3 years old with less than 10K miles. Looking to get around $4k.
Past:
2005 WK LTD. HEMI K Package - INFERNO RED
Fully loaded with Slush Mats. She was a good friend and will be missed.
drewman141 is offline   Reply With Quote
Unread 02-16-2007, 11:33 AM   #6
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
cliff,
the battery shouldn't go back just because it's an 05. They should last for a very long time.
My 94 fob worked for 6 or so years before I needed a replacement and I doubt that the fob tech has gotten worse. So, change out that battery and let us know how it works.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
Unread 02-17-2007, 05:49 PM   #7
Jeepconvert
Just as a side note if another Chrysler brand remote is being pressed, your vehicle will not respond to yours. You can try this as a prank to somebody at the office if you want. Just repeatedly press your button when you know they want to press theirs. But also keep in mind to make sure your doors lock as the same thing would happen then.
06 GC Limited daily / tow vehicle
92 TSI AWD - on the quest for more everything
Jeepconvert is offline   Reply With Quote
Unread 03-06-2007, 08:37 PM   #8
n3itn
Hi Cliff,
Is your remote key fob something new or could it have been that way forever?
Two weeks ago I bought an 06 Commander. After a day or two I discovered the second remote key fob wouldn't remotely lock/unlock the doors. The key would, however, start the engine. I called the dealer and explained what I had found and asked if the programming detailed in the manual would resolve my issue. The tech said to give it a try and if it didn't work just stop by and that it would only take a few minutes. Well after trying several times I was only able to get the second key to make one lock/unlock cycle... I went to the dealer and after two hours (and cutting a new key) they we not able to make it (or the new key (which they kept)) work. Since I was out of time I had to leave. This week I went to another dealer and explained, in great detail, the trouble but received the same "we'll get you fixed up in a few minutes" attitude. After another two hours and cutting another key they too were not able to make the second key work much less get the one they cut to work or even start the engine. Meanwhile I also discovered the headlights won't come on with the wipers as they should which makes me think there is something else going on here. I've been all over the internet and the service releases but can't seem to find what I'm looking for regarding these issues aside from this posting... that said, perhaps some of you folks can assist with some insight or direction. Thanks, Tom
n3itn is offline   Reply With Quote
Unread 03-15-2007, 10:06 PM   #9
Chef64
I had the same problem with my remote and I found one of the solder contacts inside had broke free and wasn't making contact anymore.
Chef64 is offline   Reply With Quote
Unread 03-16-2007, 02:13 AM   #10
jeff_grant
I'm having intermittent issues with one of my fobs right now as well. I've changed the battery, and it still has a "hit or miss" success rate.
I'll be ripping it open tomorrow and checking for loose connections, etc., as well as spraying it with some contact cleaner.
I've had this fob for 1.5 years, and it hasn't had any problems until about 2 weeks ago.
jeff_grant is offline   Reply With Quote
