My new Jeep, what's next? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > My new Jeep, what's next?
Poison Spyder JK LED Taillight & Wiring Harness KitsPoison Spyder JK Crusher CornersPANDEMIC-USA 50" Double row LED LIGHT BAR!! These thi
Unread 04-06-2015, 01:22 PM   #1
Adman1780
2006 WK
Hello everyone! Long time visitor, first time post...
I used to own a '98 4.0 ZJ for years and loved it. Last week on kind of a whim, I traded my beloved '99 BMW 528i for a beautiful, completely stock black 2006 JEEP WK OVERLAND w/ 80k miles. Everyone here seems knowledgeable so I won't bother you with the specs. IMO the WK is by far the best-looking body style and I needed a V8 and 4-wheel drive (and secretly wanted the Hemi), so I'm happy.
So then I did the obvious: gave her (I assume all Jeeps are ladies) a nice bath, Synthetic Oil change and coolant flush and change. Got a mechanic friend to do a thorough check and all is well. I woke up today and ordered the K&N Cold Air Intake, some E3 spark plugs and coil wire set, and a DynoMax Ultra Flo cat-back system. Should be a good start.
Soon I'm gonna give her a little lift and some more aggressive shoes. I've been eyeballing the Rough Country 2" kit and 1.5" wheel spacers and various ~31" tires. I know I got spoiled with the 5-series comfort, but the Jeep seems a too bouncy. I was thinking about upgrading the shocks/struts to some Bilstein 5100s when I do the lift.
Sooo, what should I do next?!? Other than the fore mentioned and maybe nicer headlights, I don't know where else to start. I've read some things about the catch can, upgraded steering stabilizer, performance programers, etc... I'm planning on dumping some cash on her this spring and want to make it a great all-around ride, but don't need to go overboard.
Any helpful advice or tips on parts, brands, and websites would be greatly appreciated. I enjoy your forums and look forward to your responses.
-Adam
Adman1780 is offline   Reply With Quote Quick reply to this message
Unread 04-06-2015, 01:33 PM   #2
AFguy247
2005 WK
Welcome to the forums! As for the Hemi, you should definitely add a catch can. Heard nothing but good from catch cans, and you can make one yourself for pretty cheap. Also, if you are planning on lifting it and getting bigger tires you might as well get a Superchips tuner. It will adjust your Speedo to your size tires, but also has many different tuner settings for performance or gas mileage, or even tranny shift settings.
2005 Limited 5.7L Hemi QDII OME HD
AFguy247 is offline   Reply With Quote Quick reply to this message
Unread 04-06-2015, 01:56 PM   #3
paroxysym
2007 WK
catch can for the hemi, get yourself a tuner whether it be the diablo or the superchips(seems to be the heavy favorite), if you intend on doing any offroad I would suggest either ditching the intake(low end torques gone with them) or getting a wrap for the filter- maybe look into a throttle body and a high flow drop-in and call it a day. also no need to look into a steering stabilizer, its IFS so no need for a stabilizer with a rack.
contact kolak on here for most parts, or chris over at crawl-offroad- both have great pricing.
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline   Reply With Quote Quick reply to this message
Unread 04-06-2015, 02:38 PM   #4
corswandtm
2007 WK
Ditch the E3 plugs immediately. Hemi takes OEM Champion 570 copper plugs ONLY. Many stalling problems have come and gone and all lead back to those damn plugs. Annoying to buy them from the dealer but it's a necessary evil. Search "overland stall" if you have some time to kill.
2007 WK Red Rock Limited - 5.7 HEMI w/QD-II - Stainless 22" Magnaflow muffler - AFE Stage 2 CAI - Bilstein HD shocks/struts - JBA Strut Spacers - 245-70/17 Firestone Destination AT
corswandtm is offline   Reply With Quote Quick reply to this message
Unread 04-07-2015, 01:08 PM   #5
luckyse7ens
2010 XK Commander
Glad someone mentioned this.
Too many problems with Hemi's and aftermarket plugs.
Black WK Club #152
luckyse7ens is offline   Reply With Quote Quick reply to this message
Unread 04-07-2015, 01:12 PM   #6
jbarrett
+1 Champion 570s only.
jbarrett is offline   Reply With Quote Quick reply to this message
Unread 04-07-2015, 01:19 PM   #7
luckyse7ens
2010 XK Commander
-Adam
Ditch the K&N and get a tuner instead. If you really want get an aFe dryflow drop in filter or Airaid Jr kit with dry filter. Not much positive to the Oiled K&N filters.
Plug wires are a good idea to replace @ this point.
Superchips tuner is a nice choice because you can get the Trans tuner app, to improve transmission performance.
With the Rough country lift, you should not plan to get bilstein 5100 struts (front) unless you like the nose high look. 5100 struts @ minimum lift .75" in the front in addition to your RC lift, which by itself is a leveling kit (it lifts the front more than the rear) Bilstein 4600 in the front and 5100 in the rear works nicely with the Rough country lift.
Old Man Emu spring lift is another option for ~$350 instead of the ~$180 Rough Country lift and will improve handling characteristics on and off road.
I have MOOG end links and poly sway bar bushings and bilstein shocks and I am quite happy with my ride personally.
Black WK Club #152
Unread 04-07-2015, 08:14 PM   #8
DB05wkNY
Go Pack!
DB05wkNY's Avatar
2005 WK
I have Bilstein 4600 struts 5100 rear shocks and rough country 2" lift, love it. Ride is tight and firm, but not rough. I went with 1.25" spacers and 265/70s and love the way it looks. They measure 31.70". I also have Superchips Flashpaq 3875, adjusted speedo and odo for tire size, and run performance 91 octane tune with premium gas and noticed a HUGE difference from stock. I have stock intake and exhaust, with 4.7 not the HEMI. You'll be pleased whichever route you go.
05 WK 4.7L V8 QTII, RC 2", Rustys rear springs, 1.25" spacers, GG AT2 265/70/17, Bilsteins, Superchips, custom shackle mounts, bedlined Rola rack, bedlined grill mod, KC's
SILVER WK CLUB MEMBER #136
DB05wkNY is offline   Reply With Quote Quick reply to this message
Unread 04-08-2015, 11:03 AM   #9
Bangarng
Don't forget to smoke your tail lights
Bangarng is offline   Reply With Quote Quick reply to this message
